Author Topic: Decent test leads  (Read 11167 times)
Offline ytech15
Decent test leads
« on: May 01, 2016, 08:22:43 am »
Hey,
After a while using the TL75 leads that came with my fluke, I am looking forward to upgrade them, I ordered some uni-t leads (UT-L16) which are kind of ok.. But I would like to hear some recommendations for a decent set of test leads...
Thanks
Offline cs.dk
Re: Decent test leads
« Reply #1 on: May 01, 2016, 08:40:40 am »
For small stuff, i like Fluke TL910. They are rather expensive though.
My allrounder is Fluke TL-175, works fine and they are much lower price.
« Reply #2 on: May 01, 2016, 09:12:51 am »
Avid Rabid Hobbyist
Offline ytech15
« Reply #3 on: May 01, 2016, 10:07:00 am »
Does the TL-175 have silicon wires?
Avid Rabid Hobbyist
The following users thanked this post: ytech15
Offline newbrain
« Reply #5 on: May 01, 2016, 01:24:24 pm »
Yes
TwistGuard™ is really handy, especially to probe in cramped spaces (at low voltages!) where you risk to short to something in the way.
I always ended up losing the removable caps other leads have...
Offline ytech15
« Reply #6 on: May 01, 2016, 02:31:21 pm »
Try Franky
https://www.eevblog.com/forum/buysellwanted/franky's-sales-thread/
http://stores.ebay.com/99centHobbies
Thanks. This is very useful.
Yes
Thanks.
After looking in Franky's eBay store, I found the Brymen BL21S2-T4SC... How are they compared to the TL-175?
Offline alank2
« Reply #7 on: May 01, 2016, 02:35:45 pm »
These are my favorites for my good meters:
http://probemaster.com/8000-series-standard/
The following users thanked this post: MikeLogix
Offline r4ptor
  • Country: at
« Reply #8 on: May 01, 2016, 03:07:00 pm »
I can really recommend frankys test leads. Silicone, gold coated tips, screw on adapater for banana plugs. All for a reasonable price with fast shipping.
Really satisfied with them.
Offline joeqsmith
« Reply #9 on: May 01, 2016, 03:38:59 pm »
I like the Probemaster products as well for my bench meters.   I'm not sure they offer ones that fit the standard holders you find on most handhelds.
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline noidea
« Reply #10 on: May 01, 2016, 03:58:32 pm »
Hi cs.dk
Do you mind measuring the diameter of the probes on the TL175's are they any good for backprobing into connectors with the shrouds wound back?
Offline switcher
« Reply #11 on: May 01, 2016, 04:12:45 pm »
I find most Fluke leads/probes far too large for electronics work.
Since I bought a couple of sets of each of these, I haven't used any Fluke probes.
http://www.digikey.co.uk/product-detail/en/mueller-electric-co/110012/314-1057-ND/304621
http://www.digikey.co.uk/product-detail/en/pomona-electronics/6235/501-1246-ND/737585
Offline georges80
« Reply #12 on: May 01, 2016, 05:23:39 pm »
Probemaster for the win :)
I have their 9104 probe set -> http://probemaster.com/9000-series-modular/
Pricey, but you get quality and a great kit of various modular probes/clips/etc that go well with a decent meter. I use them on my Fluke 87III and Fluke 8845A. Nice sharp tips for probing small components.
I put the straight/standard probes into my lathe to remove the 'high voltage shroud' so I can get them closer (without clashing with each other) when probing all the signal level stuff they are used for. Anything mains related I use the original shrouded versions if necessary.
cheers,
george.
Offline nanofrog
« Reply #13 on: May 01, 2016, 08:01:54 pm »
Another Probemaster user.  :-+
Regarding fitting probe holders, the modular 9000 series probes would be more appropriate (standard shape). The finger guard is on the larger side however, so they may not fit a particular meter. For example, they don't fit the back of my Brymen BM857a (older model), but have no issues fitting my Agilent U1252B.
Offline blacksheeplogic
« Reply #14 on: May 01, 2016, 09:37:03 pm »
Try these guys range:
http://www.pomonaelectronics.com/
Pomona from memory are/were part of fluke. They produce the Flukes test leads and apart from branding and a minor change in the plug are identical at a lower cost. At least some of Keithly's test leads are also built by Pomona.
Test leads are somewhat subjective and application specific, there's no 'the best'.
Offline nanofrog
« Reply #15 on: May 01, 2016, 11:03:09 pm »
They are.
The parent company is Danaher, which owns Fluke, Pomona, Keithley, and Tektronix.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #16 on: May 01, 2016, 11:10:00 pm »
Looks like Keysight 34133A is also a Pomona OEM. Keysight 34144A=Pomona 6341=Fluke TL910 to my eyes.
Offline alank2
« Reply #17 on: May 02, 2016, 01:00:23 am »
I just found that Probemaster has free US shipping now - I ordered another set of test leads for my new bench meter.  I'm going to try out one of those $3 hanging lead wall accessories too.
Offline Someone
« Reply #18 on: May 02, 2016, 01:52:50 am »
All those are the same part with Pomona as the OEM, but the Keysight package doesn't come with the spare tips? The Fluke markup is "interesting".
As with many others experience of these miniature probes, they don't have a particularly good lifespan and breaks in the fine cable occur far too often (around 1 year was typical). Since the tips and sockets are standard parts a more robust version that terminates into generic banana leads could be popular if there is an enterprising person out there with access to overmolding.
Fluke have their own surge-grip line of cables, probes, and grabbers/hooks. Most of it is targeting industrial electricians but they have a wide range of probes and grabbers suitable for electronics if you can get a chance to play with them in person before purchasing. For anything smaller I switch to logic analyser style pin header clips and probes wired onto RG316 coax.
Offline MrSlack
« Reply #19 on: May 02, 2016, 11:18:13 pm »
I don't have enough hands for probes. I didn't realise this until I got rid of the damn things.
I use a selection of random Pomona minigrabber to 4mm and 4mm patches. Plus Pomona 3788's from function generator at anything under about 5MHz on the end of a short bit of RG58/U. Anything upwards of 5MHz is soldered in circuit or BNC only.
Offline cs.dk
« Reply #20 on: May 05, 2016, 06:57:17 am »
Hi cs.dk
Sorry for the delay;
They are not good for connectors, you know the type found in vehicles, etc. Much to thick, that where the TL910 comes in.
TL175 OD 2,0 mm - TL910 OD 1,0 mm.
Offline D3f1ant
  • Doing as little as possible, but no less.
« Reply #21 on: May 05, 2016, 08:32:42 am »
TL910 are made by Pomona I think as pomona is oem for many brands. Mine are Keysight branded and cost less than Fluke TL175, so pays to shop around. They come with sprung, unsrung and stainless tips. I love crown spring tips for probing 0.4mm pitch chips, they lock/stick into the legs nicely and dont slip off.
Offline TinkerFan
« Reply #22 on: May 05, 2016, 08:41:44 am »
Dave did a short "review" of a pair of probemasters a while ago in the Mailbag. They looked pretty awesome, but I've never tested them for myself:
"The Gold probes" by Probe Master, Made in America (around minute 22):
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
Offline alank2
« Reply #23 on: May 05, 2016, 12:40:15 pm »
I got them in from the order I placed - another awesome set of 8043S.  My 8845A is now happy.  One of the best things about these is the gold plating, it is on the probe ends, on all the attachments, and the attachments screw into place.  You can't go wrong with these things.  $15.90 shipped for just the leads, but I always get the set for $27.90 that comes with alligator clips, spring hook clips, and large spade terminals.
Offline macboy
« Reply #24 on: May 05, 2016, 01:20:55 pm »
alank,
How sharp are those probes? Are the wires silicone and super flexible or PVC/etc. and not so much.
