Hi, I found a display/convenience bug when using left-handed display mode;
The tweezer "measuring diode" icon is in the wrong direction in left-handed mode. And display the "found" direction in the wrong direction.
For low-voltage diodes (1.2V), the tweezer automatically test both directions, and even displays the "found" forward direction.
But in letf-handed mode, it display the "found" forward direction the wrong way.
For high-voltage diode (3V), the tweer works only in one direction, so we should pay attention to the diode "icon" to known in which direction to test the DUT diode.
But this "icon" suggestion the forward direction is in the wrong direction (when in left-handed mode), so since the Tweezer only test one direction, it "fails" if we do not remember that we have to test the DUT diode in REVERSE-suggested direction.
Confirmed with an Atlas DCS75 Pro to be sure of which terminal is the Anode/Cathode, and tested on the test board sold with the Tweezer.
Best Regards,
