Thanks, integration is a good solution for a symmetrical signal centered in 0. Unfortunately it doesn't works well for noisy signal like the current sensed by a shunt resistor.
Still looking for a better solution. As last option I will opt for data export and external filtering, however it isn't fast as a dedicated scope function.
