Hello,
Often higher end meters specify the burden voltage of the amps range. For example, 100mV/mA would give us a 100ohm resistor. But some meters only list the voltage drop as a < X.XXX number. Like the attached image.
How do I get/approximate the resistance of the meter's amperage ranges?
Thanks!
