Poll
For mains operated test equipment, do you prefer full grounding?
Yes
4 (30.8%)
Depends on the situation
8 (61.5%)
No
1 (7.7%)
Total Members Voted: 13
Author Topic: Grounding front panel terminals on test equipment  (Read 900 times)
Offline Scratch.HTFTopic starter
« on: June 09, 2018, 02:20:48 am »
I've seen a number of pieces of mains powered test equipment which is not grounded including units with switching power supplies, and some of you may know that AC leakage current (typically around 0.2-0.5mA) in such units is at the front panel connectors which is caused by Y-class capacitors used for RFI/EMI suppression.
To avoid this kind of problem, I have a policy of using external power supplies with the mains ground tied to the secondary side ground (via an appropriately rated choke if necessary) and having the same for units with an internal power supply.
If it runs on Linux, there is some hackability in it.
