anyone with a
200Mhz DG4
062 ?
this is has been done with jtag hackery, because im too lazy to reverse yet another piece of their cryptobs.
the way it works is that u place a file <something>.CEN which needs to contain a special header, and then some crypted bits and pieces, which will then update the model type.
the message says it updated model type & serial - but i dont see that happening atm it only gets passed the new model type - by forging the right jump and tweaking the arguments of the sub (e.g. string to new model type) a bit .. you can enabled whatever u like - and yes it sticks - i went for a DG4202 ;-) ... also tried a DG4162 - and there are more
you need to have a jtag adapter to do this, and u need to open the devicecalibration is obviously off above 60Mhz (vpp, freq is fine) - time to play with the cal menu.
FW 0.4 models:ROM:CB1924 aDg4052_0: ascii "DG4052",0
ROM:CB192C aDg4062_5: ascii "DG4062",0
ROM:CB1934 aDg4072_1: ascii "DG4072",0
ROM:CB193C aDg4102_0: ascii "DG4102",0
ROM:CB1944 aDg4162_0: ascii "DG4162",0
ROM:CB194C aDg4072e_0: ascii "DG4072E",0
ROM:CB1954 aDg4202_0: ascii "DG4202",0
ROM:CB195C aDg4072a_0: ascii "DG4072A",0
ROM:CB1964 aDg4102a_0: ascii "DG4102A",0
ROM:CB196C aDg4162a_0: ascii "DG4162A",0
ROM:CB1974 aDg4202a_0: ascii "DG4202A",0
ROM:CB197C aDg4102e_0: ascii "DG4102E",0
did a fw upgrade to 0.6 afterwards, model type sticks
