Author Topic: DHO1074 horrible fan noise  (Read 1285 times)
Offline brandmeist3rTopic starter
« on: October 05, 2024, 12:22:33 pm »
Hi there,
I just got my new DHO1074 fresh out of the box directly from Rigolshop EU and I am a little disappointed.
So far I have not found any topic regarding the fan noise, so I made a quick video.
The fans are so loud, that working without headphones is not possible.
https://youtu.be/TvXG3V9IeCQ
@EEVblog Dave if you want to include the video or parts of it, you may do so.
I will tear it down, check out the fans and update the post later.
Anyway, what replacement fans should I get? Thinking of Noctua.
How was your first experience with the new DHO1000 series?
Offline ebastler
Re: DHO1074 horrible fan noise
« Reply #1 on: October 05, 2024, 12:48:37 pm »
Yes, the fans are very loud indeed -- especially considering that the enclosure is large and would have room for a large, slow-running fan. My first impression after powering up my new DHO1074 last year was "Ready for lift-off!".
I decided to return the scope, mostly for other reasons. But there is a way to make it noticeably quieter via a software change only -- the fans have PWM control, Rigol just does not use it: https://www.eevblog.com/forum/testgear/hacking-the-hdo1khdo4k-rigol-12-bit-scope/msg5231181/#msg5231181
(You can also look into installing quieter fans of course. But that's probably not something you want to do right away, in case you decide to return the scope or need a warranty repair. The software modification is easily reversible.)
Edit: There are multiple temperature sensors on the main board which can be read via a dialog in the Utility (?) menu. So you can check temperatures before & after reducing the fan speed to make sure the scope is still in a healthy state.
« Last Edit: October 05, 2024, 12:52:44 pm by ebastler »
The following users thanked this post: brandmeist3r
« Reply #2 on: October 05, 2024, 01:35:35 pm »
Yeah, ready for liftoff is the right description, it sounds like the bearings are broken.
I will try to adjust them via PWM first, thanks for pointing me in that direction.
Really a bummer, that the warranty will get void if opening the case. I might swap the fans later tho.
« Last Edit: October 05, 2024, 01:43:21 pm by brandmeist3r »
Offline NE666
« Reply #3 on: October 05, 2024, 01:51:00 pm »
It's not quiet but honestly, this is lab equipment and not the latest ipad, PC or consumer electronics item. People should hold expectations accordingly.
« Reply #4 on: October 05, 2024, 01:54:14 pm »
Agreed, but I have never experienced such loud lab equipment and I did not have that expectation.
I also have previous experience with industry test equipment, never had such a loud unit.
Also, in the video it is not as loud as irl, I guess my iPhone did some suppression there.
Offline ebastler
« Reply #5 on: October 05, 2024, 02:27:17 pm »
It's a lab instrument which one spends considerable time sitting directly in front of, trying to concentrate and debug a circuit. Given its form factor and power consumption, the DHO1000 is really unnecessarily and recklessly loud.
Offline Bryn
    • mindsConnected
« Reply #6 on: October 05, 2024, 02:40:30 pm »
And I thought the fan of the GPU of my old computer was bloody loud... only because dust got to it badly.
Anyway, when I first saw this thread, I immediately assumed that it was used, hence the loud noise it made. Are those fans meant to be this noisy though? :-//
Offline skander36
« Reply #7 on: October 05, 2024, 02:45:03 pm »
@brandmeist3r, this is not the normal sound for DHO1074.
You have some wire touching one of the fans or something broken on one of them. There are two fans.
The noise from the fans is indeed loud but definitely not this one. You should return it for checking.
LE - added short recording of the noise.
https://youtube.com/shorts/VyzlZJoBHtI
« Last Edit: October 05, 2024, 03:08:58 pm by skander36 »
The following users thanked this post: egonotto, thm_w, Fungus, ebastler, brandmeist3r
Offline ebastler
« Reply #8 on: October 05, 2024, 03:50:57 pm »
Ouch -- I had not watched the video before since "DHO1074 = too noisy" was firmly on my mind anyway... But indeed, that whirring noise is not normal; sounds like a wire or metal/plastic shaving touching the fan blades.
« Reply #9 on: October 06, 2024, 06:40:59 pm »
Update: It is the bearings, if I rotate the scope during movement the noise goes almost away.
I also checked with a screwdriver and the fans can rotate freely.
Anyway, I will send it back to Rigol and post a followup about the support experience.
The following users thanked this post: egonotto, ebastler
« Reply #10 on: October 07, 2024, 08:23:11 pm »
Update 2: I visited my makerspace and dropped it inside my bag from a bench accidentally and it must have been a cable. The noise is finally gone :D
The following users thanked this post: Someone, egonotto, ebastler
Offline 2N3055
  • Country: hr
« Reply #11 on: October 07, 2024, 09:51:37 pm »
That means it definitely a warranty return, because there is something inside the scope that is loose..
Dr. Richard W. Hamming
Offline skander36
« Reply #12 on: October 07, 2024, 09:57:54 pm »
And just because the stupid Chinese habit to seal the devices you couldn't check for yourself ...
Offline Someone
    • send complaints here
« Reply #13 on: October 07, 2024, 10:06:05 pm »
Arent the loose cabling (not tied off/retained) in the teardown? Just normal?
Offline 2N3055
  • Country: hr
« Reply #14 on: October 07, 2024, 10:49:30 pm »
And how do you teach them it is not all right to do that?
By returning stuff that rattles.
The following users thanked this post: Someone, brandmeist3r
Offline thm_w
  • Non-expert
« Reply #15 on: October 07, 2024, 10:56:48 pm »
3:35 does look like the cables should have been tied back better:
youtu.be/qEpkVa_ysaw?t=215
Thats fine but its just a waste of time if the scope is working fine now. And you risk getting a more beat up scope back, etc.
I know because I've done it for similar issues, I guarantee no one cares that one device was returned.
The following users thanked this post: 2N3055, brandmeist3r
Offline 2N3055
  • Country: hr
« Reply #16 on: October 07, 2024, 11:45:59 pm »
We are sharing our thoughts on the matter. That is what I would do. That is all.
Or open it and check. Just hoping that it is Ok now does not work for me.. Just how I am.. :-//
The following users thanked this post: Someone, thm_w, brandmeist3r
Offline Fungus
« Reply #17 on: October 08, 2024, 07:32:59 am »
I was going to suggest doing this but you beat me to it.  :)
