Author Topic: Junctek JDS6600 bad waveform  (Read 318 times)
Offline MariuszDTopic starter
« on: November 06, 2024, 04:47:12 pm »
I have bought this cheap Chinese generator recently and it has bad distortions below 100Hz.
Settings: sine wave, amplitude 5V, offset 0V.
At 1Hz waveform looks like randomly flipped half sine waves. At 1kHz it is correct.
My question for anyone who has JDS6600. Is your generator usable at 1Hz?
Offline Aldo22
Re: Junctek JDS6600 bad waveform
« Reply #1 on: November 06, 2024, 06:28:31 pm »
Are you sure it's not the scope settings? (5 s/div, ROLL mode)
Is it the same with e.g. 200ms/div?
« Reply #2 on: November 06, 2024, 09:28:18 pm »
Scope is ok, and I know how to use it. I found this error looking at irregular LED blinks.
I used 5s/div to show random nature of this weird behaviour. With 200ms/div it looks like perfect rectified sine wave or normal sine wave.
« Last Edit: November 06, 2024, 09:37:46 pm by MariuszD »
Offline Atlan
  • Country: sk
« Reply #3 on: November 07, 2024, 05:41:39 am »
Jdm doesn't have software for repair?  Feeltech, you have software and there is an item for correcting the signal flow.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
