Author Topic: DHO914 battery  (Read 604 times)
Offline MurayamaTopic starter
  • Country: jp
DHO914 battery
« on: September 25, 2024, 06:29:30 am »
Hello!
Just received a DSO9014.
Does anyone know if DHO914 can be powered with a battery?
I read something about batteries, don't use batteries except those recommended by Rigol, usual blah blah,
but I don't see any battery hatch on the case. I also tried to power it with USB-C on the back side (instead
of the power supply), and it doesn't work. They probably use a higher voltage. Any hint welcome.
Thanks!
Offline Bryn
    • mindsConnected
Re: DHO914 battery
« Reply #2 on: September 25, 2024, 06:51:00 am »
Yes, it can be powered by a battery... but unfortunately not with the one you just got (sorry if it's a wasted purchase). While both devices may share similar power requirements, they typically use different battery configurations and connections and that battery you mentioned would only work with a certain model it's made for.
However, it can be powered with USB-C power adapter or a power bank with the same kind of connectivity.
EDIT: Got ninja'd by csuhi17... damn.
  • Country: jp
Re: DHO914 battery
« Reply #3 on: September 25, 2024, 06:58:59 am »
Hello!
Thanks for your reply. Apparently some powerbanks do work, some other don't. Just for info, I was using an Anker, 20000mAh.
so be sure before buying, not to buy this model. Well, it's a bit old now, so there are probably newer types.
Thanks
  • Country: jp
Re: DHO914 battery
« Reply #4 on: September 25, 2024, 07:01:23 am »
Hello!
Yes, it can be powered by a battery... but unfortunately not with the one you just got.
How did you know? I just wrote I'm using a power pack.
By the way, what do you mean by "the one you just got"? The scope? The power pack?
Thanks
Online csuhi17
  • Country: hu
Re: DHO914 battery
« Reply #5 on: September 25, 2024, 07:14:44 am »
Powerbank.
not all powerbank compatible with the scope
Fnirsi oscilloscope = waste&regret
Online Fungus
Re: DHO914 battery
« Reply #6 on: September 25, 2024, 07:37:49 am »
The 'scope needs 12V, 36W (power delivery profile 3).
If your power bank supports that mode then it should work.
https://en.wikipedia.org/wiki/USB_hardware#USB_Power_Delivery
Offline RogerG
Re: DHO914 battery
« Reply #7 on: October 22, 2024, 12:05:04 pm »
Since USB PD 2.0 V1.2 the 12V profile is deprecated. At newer power supplies (other than the Rigol DHO "first edition" 12V PS) or power banks the DHO will always negotiate 15V/3A instead. So the power bank must be able to deliver 15V with enough power.
The following users thanked this post: Fungus
