Author Topic: DIFFERENCE HP8595E and HP8563E video monitor  (Read 1283 times)
Offline jean françoisTopic starter
« on: July 23, 2018, 12:53:30 pm »
Hello everyone,
On my HP8595E the video monitor output at the back of the camera is working properly on the video input of a TV pal secam.
on my HP8563E it does not work (unfortunately the tube is very tired) ..
In your opinion are the two video outputs of these devices should work or is the video output of the HP8563E is down?
Can someone help me?
thanks in advance
Jean François
Offline kirill_ka
  • Country: ru
Re: DIFFERENCE HP8595E and HP8563E video monitor
« Reply #1 on: July 23, 2018, 08:10:16 pm »
Those video outputs are totally different things. Video output of HP856xE can't be connected to a monitor. It's proportional to vertical deflection of CRT beam.
« Last Edit: July 23, 2018, 08:34:33 pm by kirill_ka »
« Reply #2 on: July 26, 2018, 12:40:05 pm »
Hello,
Thank you for your response and thank you for raising the doubt.
as I do not see very well on the device,
I only have one solution, it is to adapt an LCD display like the one
  from www.simmconnlabs.com/
thanks again for your information
Jean François
