Update: For those of you who may interested in the result, I have actually successfully captured several sections of a Ethernet packet, each was shifted by utilizing the "Delayed time base". And by gluing them altogether, I actually saw the waveform of 56 bits of preamble and 8 bits of SFD.
Here is the link :
https://goo.gl/photos/3EQojfnYpNPd4fWz7Hope you enjoy it too!
Hi all! I've been trying to use my old digital oscilloscope (Tektronix TDS 340AP) to observe an Ethernet signal.
Basically what I have done is only to force the NIC (Network Interface Card) to work at 10Base-T (10Mhz). Thus the signal is basically 10Mhz and encoded by the so called "Manchester Code", which is pretty easy to interpretate. You can check the wave form I got from the below link:
https://goo.gl/photos/3EQojfnYpNPd4fWz7The problem is, as described in Wikipedia (
https://en.wikipedia.org/wiki/Ethernet_frame), every ethernet packet has a
49bit 56 bit "preamble" header. No matter however I change the setting of trigger function, the oscilloscope will always trigger at the first slope of the preamble header signal. Since the preamble is supposed to be simple repeat of 0 and 1, I really want to "skip" the preamble part and trigger at a later timing. More importantly, since the memory depth of my scope is limited, it's impossible for me to capture the whole signal of a ethernet packet.
My question is, is there any setting or trick can make it possible to delay the trigger timing?
