Author Topic: RF Test Automation  (Read 335 times)
Offline vinoTopic starter
RF Test Automation
« on: April 12, 2024, 05:27:20 pm »
Good Day Guys,
I would like to ask expert advices because I'm very interested in doing RF test automation. As a newbie I would like to know where should I start? Is there a step by step procedure that I need to follow?
Is there any websites, reading materials ,videos and etc. that this forum can provide. Thank you very much
Online alm
Re: RF Test Automation
« Reply #1 on: April 12, 2024, 07:18:43 pm »
This topic has been discussed a couple of of times on this forum (not specific to RF, but the principles are the same). Try using google (with site:eevblog.com) to search for topics like test automation, gpib or lxi. You will have to decide on an automation platform like NI LabVIEW (graphical programming, which might (or might not) be easier if you don't have much of a programming background), a real programming language like Python or C#, or scripting embedded in a tool like lxi-tools. It also depends on what type of instruments you use: Are they modern stand-alone instruments with LXI, older stand-alone instruments with GPIB or mainframe-based instruments like VXI or PXI(e). You probably already have some instruments.
Depending on the type of tests, you may want to look into an RF switching matrix that can change connections under computer control. This allows you to for example connect 10 DUTS and 5 test instruments and connect each DUT to each test instrument in sequence.
There is no step by step procedure because the steps depends on your use case. Just like there's no step by step procedure of "how to design a PCB". What kind of instruments do you have? What kind of programming background do you have and in which language(s)? What kind of tests are you planning to run?
Offline Bud
« Reply #2 on: April 12, 2024, 08:58:25 pm »
@OP do not double post same question in multiple subforums, this is not welcome here.
The following users thanked this post: Kean, alm
