Author Topic: Digital multimeters sucks  (Read 14210 times)
Offline 001Topic starter
  • Country: aq
« on: April 08, 2019, 03:31:23 pm »
This is no more then crap toys
I`m going with my analog one for four decades
No batteries
No remorse
Offline Fungus
Re: Digital multimeters sucks
« Reply #1 on: April 08, 2019, 03:35:22 pm »
Thanks for sharing.
The following users thanked this post: brabus, Ysjoelfir, kj7e, luma, 2N3055
Online tggzzz
« Reply #2 on: April 08, 2019, 03:35:45 pm »
No batteries
No remorse
That is difficult to distinguish from a (poor) troll. Not good.
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #3 on: April 08, 2019, 03:35:53 pm »
Thanks for SPAMming.
Offline jasonbrent
« Reply #4 on: April 08, 2019, 03:38:08 pm »
OP, did you try to install the firmware update? It should fix the issue you are having.
The following users thanked this post: tooki, Ysjoelfir
Offline ArthurDent
« Reply #5 on: April 08, 2019, 03:46:50 pm »
Different tools serve different purposes and understanding how a tool (DMM) works by reading the manual may help. If you can stand dead batteries on ohms, loading of circuits on volts, and low accuracy, an analog meter may serve your limited needs.
Offline Cnoob
« Reply #6 on: April 08, 2019, 03:54:30 pm »
Sounds like someone has thrown their a rattle out the pram or should I say DMM.
Can an analogue  meter survive a metre drop?
« Last Edit: April 08, 2019, 03:59:13 pm by Cnoob »
The following users thanked this post: Electro Detective
Offline windsmurf
« Reply #7 on: April 08, 2019, 04:27:54 pm »
Turbos suck even more.  Nothing but crap ICE use'em.  3-phase induction motors FTW!
« Reply #8 on: April 08, 2019, 05:00:06 pm »
Obviously the OP never uses the resistance ranges then, so a simple battery tester might suffice [emoji23]
Offline schmitt trigger
  • Country: mx
« Reply #9 on: April 08, 2019, 05:16:12 pm »
I love retro-electronics, which also means analog multimeters. I recently purchased one in Tokyo's Akihabara district.
But other than to use them to null or calibrate a circuit which uses trimpots, really a DMM is a far superior tool.
True, their batteries go flat, but they last a looooong time. And most DMMs have an auto-shutoff feature anyways.
« Reply #10 on: April 08, 2019, 05:36:39 pm »
The batteries on an analogue meter for the resistance ranges will also go flat in time so where's the difference between an analogue or a DMM in that respect?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #11 on: April 08, 2019, 05:53:23 pm »
Let me guess: you blew one of your DMM puppies with your HV power supplies? Or the mention of batteries indicate you had a major leakage problem?
I hope it wasn't either the 87V or the 117.
Offline kj7e
  • Damon Stewart
« Reply #12 on: April 08, 2019, 05:57:06 pm »
The funny thing is, I use a Simpson 260 as my "Monitor" on one of my LTZ1000A reference.  Turns out my reference is pretty solid according to the Simpson!
Offline kj7e
  • Damon Stewart
« Reply #13 on: April 08, 2019, 06:13:57 pm »
an 8.5 "needle" analog meter split into decades, it will be quite the picture in the LTZ thread for sure.
Ill put one up when I get home later today.
Offline floobydust
« Reply #14 on: April 08, 2019, 06:32:11 pm »
Can't measure ohms without batteries! Simpson 260 on R x1 puts out 130mA! Great for finding poor connections.
It's the batteries sagging, drifting, keep turning zero adjust. Yuck.
Digital multimeters only burned me once- measuring mains voltage and I got good V readings due to leakage currents. An analog multimeter read zero. Would have saved me hours.
Low Z voltage is an important feature.
« Last Edit: April 08, 2019, 06:54:37 pm by floobydust »
Offline luma
« Reply #15 on: April 08, 2019, 06:40:58 pm »
My stupid DMM has misspelled "pluses" and they still haven't released a firmware update  :-BROKE
Online tggzzz
« Reply #16 on: April 08, 2019, 06:49:49 pm »
Not always. Often changes and noise are easier to interpret on an analogue meter. Hence life-critical instruments are often have analogue displays, e.g. altimeters, ASI indicators and artificial horzions.
If I'm just noodling around a circuit to find gross faults, it is often faster with an analogue instrument.
Offline djacobow
  • takin' it apart since the 70's
« Reply #17 on: April 08, 2019, 06:51:17 pm »
My Simpson 260 Series 6 has two batteries for ohm mode, but one of which is also required if you want the overload protection circuit to work.
« Reply #18 on: April 08, 2019, 06:51:34 pm »
Perhaps the real issue is the user, not the DMM.  ::)
The following users thanked this post: rsjsouza, Ysjoelfir, Synthtech
Offline Synthtech
« Reply #19 on: April 08, 2019, 06:54:47 pm »
Multimeters aside, is the OP trying to reduce the information signal-to-noise ratio of the forum again?
The following users thanked this post: rsjsouza, tooki, Ysjoelfir
Offline floobydust
« Reply #20 on: April 08, 2019, 07:00:32 pm »
Which battery are you referring to? 1.5V or 9V. Real 260's use a 22.5V battery  :-DD
Online tggzzz
« Reply #21 on: April 08, 2019, 07:01:59 pm »
My emphasis :(
Offline djacobow
« Reply #22 on: April 08, 2019, 07:03:34 pm »
It's the 9V. It's right in the schematic you posted. Yeah, this one isn't uber vintage. It was my dad's, though, so has sentimental value, even if it uses batteries I can still buy at the drugstore.
The following users thanked this post: Synthtech
Offline 0culus
« Reply #23 on: April 08, 2019, 07:18:07 pm »
My emphasis :(
Every forum I've ever been on has that one poster...  :palm:
Online tggzzz
« Reply #24 on: April 08, 2019, 07:23:35 pm »
My emphasis :(
There are a few others here too, but not very many. I'm sure you have your candidates; I'm not going to draw attention to mine.
The forum rules are sensible - and are reasonably enforced by the moderators and members.
The following users thanked this post: newbrain, Synthtech
