Author Topic: Digital multimeters sucks  (Read 14198 times)
Offline vk6zgo
Re: Digital multimeters sucks
« Reply #50 on: April 09, 2019, 11:29:35 am »
Sounds like someone has thrown their a rattle out the pram or should I say DMM.
Can an analogue  meter survive a metre drop?
Yep!
I dropped an AVO 8 off the top of a transmitter---about 2m.
I put my foot out (wearing "Japanese safety boots" ;D) to prevent damage to the meter ----Ouch! Not a good idea!!
The AVO was fine, so was my foot -------after a "few" hours, & some Paracetamol !
Online bd139
« Reply #51 on: April 09, 2019, 11:54:26 am »
Think you were lucky. Usually if you fart in the general direction of an Avo it breaks.
On the bench this week:
I like both.
The following users thanked this post: 001
Offline vk6zgo
« Reply #52 on: April 09, 2019, 12:07:26 pm »
 AVO 8 has  DC current scales down to 250uA, but unfortunately the lowest ac scale is 100mA.
http://www.richardsradios.co.uk/avo8.html
For generic voltage rail checking, there is not that much to choose from between it & my Fluke 77.
A problem the latter has that the AVO has not, is that some waveforms when looked at on the DC range read as a steady DC voltage.
On one occasion, I looked at the "boost HT" on a TV, which was supposed to be around 130v.
It read about 105v--- a bit low, but not that bad.
On checking the same test point with a 'scope, the "DC" (half wave rectified 15kHz from an overwinding on the H.O. Transformer) was obviously not filtered, due to a faulty low ESR electro.
With a ordinary analog meter, the problem would have been immediately evident.
That said, as most of the time, I use an analog Oscilloscope "free running" in the DC coupled mode for checking power rails, etc, I am quite happy with the 77 for most of the other things.
Offline joeqsmith
« Reply #53 on: April 09, 2019, 12:14:10 pm »
I just want to measure a few mA AC.
The 34401a can't measure a few mA AC on its one and only front-panel range.
Through IEEE-488 you can switch in an AC mA range but I have not checked it's accuracy.
It's never come up that I needed it which explains why I was not aware of that feature.  A quick search and sure enough:
https://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=1000001267:epsg:faq&nid=-31895.536880933.02&id=1000001267:epsg:faq
For fun I gave it a try and it seems to work.    My meter is one of the early versions. I think I bought it the same year it was released.  So there shouldn't be any compatibility problems when using this command.
Now I wonder if there are other undocumented features like this.
I should mention that I did not try setting the meter to slow. This was with the defaults.
« Last Edit: April 09, 2019, 12:22:32 pm by joeqsmith »
The following users thanked this post: Kean, Marco1971
Offline wraper
  • Country: lv
« Reply #54 on: April 09, 2019, 12:46:02 pm »
Why isn't the 10 mA ac current range included as one of the standard ranges for the Agilent 34401A? It is because adding a 100 mA range would have added significant cost to the instrument for a measurement that is infrequently used, and implementing the 10 mA range without the 100 mA range would require the long explanation, that you are currently reading.
LOL
Offline 001Topic starter
  • Country: aq
« Reply #55 on: April 09, 2019, 04:48:45 pm »
Honey, why did You wrote tons of shitposts here?
Keep in mind what analog dmm is a root way to understand metrology
and it did`t require expencive batteries
and etc
stop digitise world! stay ortodoxy!
« Last Edit: April 09, 2019, 05:55:14 pm by 001 »
Offline hwj-d
  • save the children - chase the cabal
« Reply #56 on: April 09, 2019, 05:22:54 pm »
I have one with 6 and a half needles, every from zero to nine, except the half. That solves the problem...  :-DD
« Reply #57 on: April 09, 2019, 05:29:48 pm »
Avo 9 has 10A, 1A, 100mA, 10mA, 1mA, 300uA and 50uA DC current ranges which can be very handy and on the AC side has 10A, 1A, 100mA and 10mA thuis making more suitable for an electronics bench. I think the Avo 8 was more of an electricians meter.
Offline joeqsmith
« Reply #58 on: April 09, 2019, 05:38:49 pm »
After having the meter unplugged for several hours, the feature is indeed still enabled as the post suggests.  Just select manual range and it will show up as an option.
I then selected the longer filter and it does appear to improve the accuracy.    For fun, I tossed it across a 1 ohm 0.1% shunt which is typically how I would use the meter.   Default filter settings.
The following users thanked this post: 001, Marco1971
Offline Stray Electron
« Reply #59 on: April 09, 2019, 06:03:11 pm »
we need sanwa to send a rep here to answer some questions about 360TR
its annoying to keep seeing keysight and keithley threads  ;)
  The reason that you see so many Keithley and HP (aka Keysight aka Agilent) threads here is because their meters (and other equipment) WORKS the way it's supposed to without a lot of IFs, ANDs, BUTs or MAYBEs, unlike a lot of cheapo brand X crap that people are buying from China and some other 2nd rate counties.
I wouldn't consider Sanwa and Hioki "2nd rate counties" (sic) - they are simply not very popular outside of their COO (Japan). Similar case can be done for Gossen and others.
BTW, your actual post is pretty ignorant and dismissive of reality, as there are several threads that talk about "lot of cheapo brand X crap" - Siglent, Rigol, Instek, Uni-T and others are pretty common around here.
   Yeah and good luck trying to get a service manual, parts list or anything else for any of those brands. I have Anritsu, Yokogawa and other Japanese made equipment and it's all well built but there are no manuals for any of it. The only company that has ever supplied me with any information was Misubishi and they had one of their engineers mark up a Japanese language manual and fax it to me. My hat is off them. One more thing: I really wasn't talking about Japan.  Maybe you consider it to be a 2nd class country but I definitely wouldn't. Their electronics design and construction is first class but their tech support outside of Japan leaves a lot to be desired.
  "Siglent, Rigol, Instek, Uni-T and others are pretty common around here."
   Those aren't exactly what I would call brand X but I guess you don't understand the difference. But still, being common doesn't mean that it's well built.  Radio Shack brand is common but most of it is still junk! Lafayette is only slightly better.   Go open any of the brands that you named and look at the build quality and compare that to pictures of the tear downs of any HP built test equipment that have been posted on this forum and then try to convince me that any of them are as well designed or well built.  And that is before we talk about the availability of parts, service manual, operators manuals, etc.
  3roomlab  said: "we need sanwa to send a rep here to answer some questions about 360TR"
    Did anyone ever get a reply from Sanwa about this?  Has anyone ever gotten a response from Sanwa about any technical inquiry???  In fact, has anyone ever gotten a positive response from any Japanese or Chinese test equipment company company for technical support?
Offline Electro Detective
« Reply #60 on: April 09, 2019, 10:15:05 pm »
and etc
Dear Sir/Ma'am,
I get what you are saying about some technology that not always does us any real favors
that need batteries which may be expensive, and a hassle to buy and keep warm in Antarctica    :-\
FYI you can learn a bit about metrology with fast and precise digits too, as well as a moving needle  :clap:
You kicked off this post, that's drifting off toward   'analogue meter memory lane...'    8)
but 3 pages later still not advised which 'Digital multimeters sucks' model/brand you have,
what the application/s were to instigate the sucking POV
and which analogue meter/s you use that do not suck (yet)
Throw us a bone here mate   :popcorn:
« Last Edit: April 09, 2019, 10:19:16 pm by Electro Detective »
The following users thanked this post: janoc, Ysjoelfir
Offline DaJMasta
    • medpants.com
« Reply #61 on: April 10, 2019, 12:53:44 am »
Not sure why an analog movement would be considered "metrology" in the last 50 years, honestly.  Sure, there are accurate ones, but digital technologies and being able to display finer gradations have dominated all the most sensitive and highest resolution measurements in recent decades.  There are personal preference things and natural averaging/quick display things that analog meters can offer, but those aren't really in the realm of metrology.
Maybe the digital meters you have used haven't been well suited to your applications, maybe your analog meters are particularly good and have been well suited to your applications, but the fact is that the precision of a digital readout from a properly specified acquisition system blows an analog meter movement out of the water every time.  Even when the sensitivity and the dynamic range of the analog system are the same (or even superior), you can get about 3 digits worth of display precision on a regular sized movement, and you simply can't distinguish finer gradations which many digit digital displays have no trouble showing you - and in many applications these fine details are essential for developing, troubleshooting, or characterizing the DUT.
If you like analog meters, great.  If you have had a bad experience with digital ones, that's too bad.  Don't know how that invalidates the entire architecture across dozens of brands and hundreds of models that have been obviously preferred and market-dominant for several decades.
But I gotta say.... whining about needing a battery....... yikes.  So your preferred analog meter doesn't even have an ohms range?  I'd prefer something with features from at least the 50s...
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #62 on: April 10, 2019, 02:10:08 am »
   Yeah and good luck trying to get a service manual (...)
Way to go moving the goalposts from "WORKS" to "SUPPORT"...  :=\
Hey, I am not calling any country 2nd class - your post is the one that was dismissive of anything else other than these two brands whose HQs are in the US.
Hey, your post was the one that put every other brand on the market in the same bucket. It's not my fault that you were not very specific and came across as ignorant of the plethora of brands and quality levels.
« Reply #63 on: April 10, 2019, 02:36:41 am »
YES. Advantest/ADC Corp. Japan GM Sales re request for manual and information in February and others in the past successful responses from other Asian countries/companies China included over time.
In the last month Keysight recently has FAILED to respond in any form to a support request via email and my phone call to their support line is still awaiting a response by comparison.
You Rash Generalisation/Slight against Asian manufacturers is WRONG.
The following users thanked this post: rsjsouza, Kean
« Reply #64 on: April 10, 2019, 01:09:57 pm »
The point is that any multimeter, unless it is mains driven bench meter uses batteries, even a analogue one. :palm:
Online tggzzz
« Reply #65 on: April 10, 2019, 01:14:30 pm »
Moving coil meters are useful for many purposes, even if their batteries are missing.
However, to use them to measure resistance would require an external power source of some sort.
Online bd139
« Reply #66 on: April 10, 2019, 01:15:58 pm »
 :popcorn:
Offline sambonator
« Reply #67 on: April 10, 2019, 01:54:44 pm »
I get responsive support from Hioki all the time.
« Reply #68 on: April 10, 2019, 10:51:32 pm »
I think that the OP deliberately asks these kind of thought provoking questions and then quietly slips out the back end without really divulging if there was ever a serious reason for the question, I seem to remember a few other similar type of threads in his or her name  :box:
Offline windsmurf
« Reply #69 on: April 10, 2019, 11:18:24 pm »
Is this a conspiracy by Dave to get more traffic to his Forums, and hopefully to his blogs?   >:D
We should help him.. let's start a "Fluke sucks" thread  :-DD
Offline joeqsmith
« Reply #70 on: April 10, 2019, 11:37:12 pm »
If you really want to drum up some drama, you need to start a "UNI-T sucks" thread.
« Last Edit: April 10, 2019, 11:43:17 pm by joeqsmith »
Offline joeqsmith
« Reply #71 on: April 11, 2019, 12:06:20 am »
Yep!
For some reason, my cheap analog meter didn't hold up very well.  Perhaps a cheap digital one would be more robust.
https://youtu.be/WCIpm8peQSU
« Reply #72 on: April 11, 2019, 12:26:39 am »
Easily a 1000 page monstrosity here in a day if anyone dares post   "Top 10 Digital Multimeters that suck"
kicking off top of the list with Uni-Tee, Harbor Fright wheel chocs, and other ThreeHungLow produced promo freebies,
including cheapies labelled for CAT 4  (Tropical Cyclone survivability...in a Pelican case  :-// )
Hopefully some Antarctican member/s will eventually chime in to stick in the boots on what may be a sensitive topic   :popcorn:
 ;D
Offline joeqsmith
« Reply #73 on: April 11, 2019, 12:46:27 am »
 ;D
How about "Top 10 Digital Multimeters that suck and why".  I've got a few picks already if you dare start this shit war!  :-DD
Offline schmitt trigger
  • Country: mx
« Reply #74 on: April 11, 2019, 12:57:23 am »
If you think that those questions would create a feeding frenzy, you have not seen photography forums.
Just ask: which camera brand is worse? Canon or Nikon? And watch the fanboys shred themselves to molecules.
Or the timeless dilemma: do REAL photographers prefer film over digital? Such a thread will grow in no time to several  hundred messages long.
