Author Topic: Digital Oscilloscope Chart  (Read 201765 times)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
Re: Digital Oscilloscope Chart
« Reply #150 on: November 14, 2017, 06:32:01 am »
I might be wrong, but Tektronix ensures 10,000 wfm/s in TBS2000 series datasheet, the search buttons is finally enabled, Hi res mode and the brightness is adjustable in firmware version V1.23.
Thank you for the information, i found the link to the datasheet.
http://direct.tek.com/sites/tek.com/files/media/media/resources/TBS2K_compare_chart.pdf
I am updating the Tektronix series today. Please wait. :)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #151 on: November 14, 2017, 11:34:25 pm »
Added Tektronix MDO4000C and fixed the waveform update rate or TBS2000.
Thank you for the comment from ErnestoFB :)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #152 on: November 15, 2017, 01:09:09 pm »
Added Tektronix 5 Series MSO :)
The following users thanked this post: Arjen_Arg
Offline Arjen_Arg
  • Country: ar
« Reply #153 on: November 18, 2017, 04:18:03 pm »
This is really great, thank you for your work!
The following users thanked this post: fanOfeeDIY
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #154 on: November 25, 2017, 09:53:57 pm »
You are most welcome :)
« Reply #155 on: November 25, 2017, 10:16:58 pm »
In the next few days there'll be other Siglents to add to the list, please keep an eye out for them to appear on Siglent websites. 4 channel X-E models, SDS1104X-E and SDS1204X-E.
TIA.
Avid Rabid Hobbyist
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #156 on: November 25, 2017, 10:34:29 pm »
TIA.
Thank you for the info :)
I will check the website.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #157 on: November 29, 2017, 02:03:06 pm »
Hi
I Added SIGLANT SDS1104/1204X-E models.
May be the next is Uni-T?
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #158 on: November 29, 2017, 02:10:51 pm »
I also see the limitation of the chart since all the Oscilloscope have different characteristics just can not be compared by the chart.
I might need to add comments section.
Some Tektronix have superb Spectrum Analyzer.
Some has one ADC shared with all channel which reduces the sampling rate from 1G, 500M, 150M respectively with using 1ch, 2ch, 4ch at the same time while other has two ADC or have noe sampling rate drop for 4 channels.
No information about FFT feature in the chart and etc.
Offline cowasaki
« Reply #159 on: January 14, 2018, 10:41:56 pm »
Sorry if I've missed it in all the posts but what about the scopes from UNI-T I know they are not maybe considered a top brand but I have a UNI-T UTD4202C 200MHz digital storage scope with logic analyser and I've found it very useable.  If I could have afforded a Fluke or some other brand like that I would have done!
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #160 on: January 18, 2018, 03:10:03 pm »
I would like to have UNI-T in the chart.
I also do not seem to have reflected the changes of the price and default options on ds1054z.
Would you like to add comments for UNI-T in the chart :)
https://docs.google.com/spreadsheets/d/1rtPqMAkNw2bSkqocuc7zcYkl57fsdPVlxzyqcJmbKIc/edit?usp=sharing
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #161 on: January 19, 2018, 12:25:29 pm »
The R&S RTC1000, RTM3000 and RTA4000 are added.
Thank you for improving the chart.
Offline timkoers
« Reply #162 on: February 24, 2018, 09:42:18 pm »
It looks like you forgot the Siglent SDS-1204X-E, or did you just not put it in there because it virtually has the same specs as the SDS-1202X-E but with two extra channels?
« Reply #163 on: February 24, 2018, 10:11:23 pm »
Yes it has been overlooked it appears but it won't be because of SDS1202X-E as the 4 ch version has more features.
The feature set of both X-E 4ch models is the same excepting BW of course.  ;)
Avid Rabid Hobbyist
The following users thanked this post: timkoers
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #164 on: February 25, 2018, 07:07:24 am »
I had to include SDS-1204X-E to SDS1104X-E's column, the chart is already large and to keep the size manageable I am merging the models with different BWs.
Offline bullonwheels
« Reply #165 on: June 02, 2018, 11:27:07 pm »
Hi Please help me, I have Tektronix 4104C at work and I want something to work on at home. I am planning to buy 1052B for approx $500. Is it worth ?
« Reply #166 on: June 02, 2018, 11:55:53 pm »
Welcome to the forum.
Tek 1052B has a only miserable 2.5k of memory, would you be happy with so little in a DSO ?
I get the UI will be similar to what you're used to but maybe you should look at a more capable DSO.
My 2c.
Avid Rabid Hobbyist
« Reply #167 on: June 03, 2018, 12:51:56 am »
Thank you Tautech.
I am planning for siglent 1202E. Confused between siglent and Rigol now.
The following users thanked this post: enut11
« Reply #168 on: June 03, 2018, 01:29:28 am »
Thank you Tautech.
What model Rigol are you looking at ?
Would you be happy with only two channels of the 1202X-E ?
For what you were to spend on the Tek you can have a SDS1104X-E.
Avid Rabid Hobbyist
« Reply #169 on: June 03, 2018, 05:20:33 pm »
Wow Tautech you are life saver :) I just cancelled Rigol 1052 and ordered Sds1204 :)
Online Wolfgang
    • Electronic Projects for Fun
« Reply #170 on: August 03, 2018, 01:15:50 am »
... just for completeness and because it is an awesome scope, I would add the Keysight S Series (Infiniium).
10Bits resolution, up to 8GHz, ... not bad in my eyes.
Offline johnfiott
  • Country: mt
« Reply #171 on: September 25, 2018, 10:00:55 am »
Excellent job. Thanks for taking the time to research this. I am looking to buy my first oscilloscope and am considering a Hantek.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #172 on: October 06, 2018, 01:47:47 pm »
I have not updated the chart after January and it is already October now.
I have very limited spare time these days, I may have time next weekend.
Many good scopes were released.
I welcome any commenting for the new scope on the sheet, then it will help me updating it. :)
The following users thanked this post: rs20
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #173 on: November 24, 2018, 08:03:06 am »
I am really behind updating the chart.
Is there other models than bellow have released after my last update?
Keysight Infiniium S-Series
Rigol DS5000
Rigol MSO5000
I just wanted to know what models are missing in the chart to start getting the datasheets.
Offline commongrounder
« Reply #174 on: November 25, 2018, 12:46:14 am »
Have you gotten the Rigol DS/MSO7000 series?
