Author Topic: Digital Oscilloscope Chart  (Read 1032704 times)
Offline fanOfeeDIYTopic starter
  • Country: jp
    • YouTube Channel
« on: May 22, 2015, 03:00:39 pm »
Updated on 30 December, 2021
I have attached the chart listing the many well known digital Oscilloscopes in the market.
All the model have pros and cons beyond the numbers in the charts. Check details in the datasheet or comments in the forum.
I was looking for a good forum, since I was considering to buy an oscilloscope, and I found the eevblog is an excellent place.
I wanted to contribute something and maybe my chart I made might be useful for someone.
(It was about April 2015 when I started to make a chart. I was considering buying around 800 to 2000 USD model, and the columns are optimized for this range of scopes. Definitely the high-end models requires much broader specs)
I would appreciate any kind of comment, especially for unknown columns and mistakes.
Sorted by the price based on the feedback.
Adding more models are coming.
The link to the Google Drive: (anyone could add comments)
https://docs.google.com/spreadsheets/d/1rtPqMAkNw2bSkqocuc7zcYkl57fsdPVlxzyqcJmbKIc/edit?usp=sharing
@CMASupra has made the great chart more details on the analog front end, logic analyzer, FFT, bode plot (frequency response test) and not only for each series but also models in series.
It would be really nice to merge all the in one charts, might happen some time in the future.
Excsel sheet by @CMASupra
https://www.eevblog.com/forum/testgear/digital-oscilloscope-comparison-chart/?action=dlattach;attach=1066268
The image of CMASupra is attached next to my chart images.
Chart by @CMASupra
Changelog (suggested by):
*Changed from having models on the row and specs on the columns, to specs on the row and models on the columns. (videobruce)
*Changed from jpg to png which reduced the mosquito noise.
*Added excel sheet on the first post. (videobruce)
*Sorting the chart by prices. (videobruce)
*Fixed specs of RIGOL's segmented memory. (miguelvp, Stupid Beard)
*Added SIGLENT. (tautech)
*Uploaded excel file to Google drive and added to the first post. (rs20, tautech)
*Added GW-Instek, Hantek and Iwatsu. (Muxr)
*Fixed the specs of RIGOL's waveform update rates. (miguelvp)
*Added column for whether has individual vertical knobs for each channels.
*Added Imperial to the size and weight since most of the datasheets are in Metric. (videobruce)
*Added OWON and GRATTEN (ATTEN). (Muxr)
*Added a few models.
*Reduced the row height by widening the columns so only two lines are needed instead of three and others. (videobruce)
*Added Rohde & Schwarz. (Muxr)
*Fixed the segmented mem sections of HMO1000 and HMO3000 (Gunb)
*Changed model numbers in columns to reduce the width of excel sheet. (videobruce)
*Added Dimensions (WxHxD) which only had width originally. (videobruce)
*Added Tektronix and Keysight 1052B models. (ez24)
*Modified the columns of Digital Inputs. (ez24)
*Modified from stating $300 range to $300-$500. (ez24)
*Added Serial Decoding feature to the columns (ez24)
*Added GW-instek GDS-1000B
*Added RIGOL DS4000
*Added SIGLENT SDS1000X
*Added Lecroy WaveJet Touch
*Added SIGLENT SDS2000X
*Added LeCroy WaveAce 1000
*Added LeCroy WaveAce 2000
*Added LeCroy HDO4000
*Included typical 4ch, 500Mhz, 5GHz Sampling models
*Added R&S RTE1000
*Fixed some mistekes in serial decoding section
*Update the memory of Siglent SDS2000 reflecting the new V2 firmware change (rf-loop and tautech)
*Added R&S RTE1000
*Added Iwatsu DS-5600A
*Added Keysight DSO-X 6000X
*Added R&S HMO1202
*Added SIGLENT SDS1000DL, SDS1000CML+, SDS1000X+
*Added R&S RTM2000 by AndyP (Thank you!)
*Added Micsig models by AndyP (Thank you!)
*Added Many R&S models (by Rich, thank you!)
*Added Keysight DSO-X 1000X
*Added Tektronix TBS2000
*Added Many Pico models (by ADT123, thank you!)
*Updated SIGLENT models (by Siglent, thank you!)
*Added RIGOL DS2000A-S (comment from Lance)
*Added RIGOL 1000Z-S (and plus) models (comment from Zafrullah)
*Added Function Generator feature to the column
*Added and revised Keysight EDUX1000A, EDUX1000G, DSOX1100A, DSOX1100G on the chart
*Added Tektronix MDO4000C and fixed the waveform update rate of TBS2000 (Comment from ErnestoFB)
*Added Tektronix 5 Series MSO
*Added SIGLENT SDS1104/1204X-E models
*Added R&S RTC1000, RTM3000 and RTA4000
*Added Keysight Infiniium S-Series
*Added RIGOL DS5000, MSO5000, MSO/DS7000
*Reorganized chart to able to use filter feature (Comment from bitbanger)
*Fixed TDS3000C  Vertical resolution is 9 bits (Comment from udou2048)
*Added Keysight DSO-X 1200X
*Added SIGLENT SDS2000X-E, SDS5000X
*Fixed typo of "SIGLANT" to "SIGLENT" (Thanks Vell)
*Added Tektronix 3 Series MDO, 4 Series MSO
*Added LeCroy HDO4000A
*Split Columns of Display size, resolution and touch (Comment from geirendre)
*Added youtube link to SIGLENT SDS5000X
*Added OWON SDS1000, XDS2000, XDS3000A, XDS3000E, XDS3000AE, XDS3200, XDS3200A, XDS3300
*Added SIGLENT SDS2000X-Plus
*Added LeCroy WaveSurfer3000z, WaveSurfer4000HD, HDO6000A
*Added RIGOL DS1000Z-E
*Updated RIGOL DS1000Z, MSODS2000A to match current lineups
*Updated Keysight InfiniiVision2000X to match current specs after improvements in 2018
*Added OWON USB oscilloscope series, VDS1000, VDS2000, VDS3000, VDS6000 (Thank you, @BetterAndBetter)
*Added Keysight InfiniiVision1200X, EDUX1052 and improvements in Feb 2020.
*Added Tektronix TBS2000B
*Added PicoScope 3000, 5000D and fixes
*Updates and fixes on Rohde & Schwarz
*Added GW-instek MDO-2000E, MDO-2000A, GDS-3000
*Added PicoScope 6000E and fixes
*Added Yokogawa DLM3000
*Added LeCroy T3DSO1000, T3DSO2000
*Added Keysight Infiniium MXR Series
*Revised Price Rage Column for filtering/sorting (Comment from Zom-B)
*Added Micsig STO1000C STO1000E
*Fixed spelling "capasitive" to "capacitive" (Comment from jimjam)
*Started revising the descriptions of Max Sample Rate, Max Waveform Update Rate and Memory Depth to show the performance change from number of channels used.
*Added Micsig MS500
*Started to add ENOBS
*Separating columns the models which specs differs of equipped channels
*Added Tekronix 6 Series MSO
*Added SDS1104X-U
*Added Tekronix 6 Series MSO B
*Added SDS6000A Series
  • Country: jp
    • YouTube Channel
Re: Digital Oscilloscope Comparison Chart
« Reply #1 on: May 22, 2015, 03:06:05 pm »
RIGOL
SIGLENT
« Last Edit: December 30, 2021, 12:34:47 pm by fanOfeeDIY »
  • Country: jp
    • YouTube Channel
« Reply #2 on: May 22, 2015, 03:06:37 pm »
Agilent/Keysight
« Last Edit: June 29, 2020, 03:36:10 pm by fanOfeeDIY »
The following users thanked this post: tazmadman
  • Country: jp
    • YouTube Channel
« Reply #3 on: May 22, 2015, 03:07:07 pm »
Tektronix
« Last Edit: December 20, 2020, 10:42:22 am by fanOfeeDIY »
The following users thanked this post: Bravo, hunterj5
  • Country: jp
    • YouTube Channel
« Reply #4 on: May 22, 2015, 03:07:40 pm »
LeCroy and YOKOGAWA
Rohde & Schwarz
Pico
Micsig
OWON
GWinstek and IWATSU
Hantek and GRATTEN (ATTEN)
« Last Edit: December 30, 2021, 12:36:08 pm by fanOfeeDIY »
  • Country: jp
    • YouTube Channel
« Reply #5 on: May 22, 2015, 03:09:07 pm »
The selection of the model is my subjective selection ;D
Some of the comments in the chart is my subjective impression too.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #6 on: May 22, 2015, 04:39:10 pm »
Not wanting to be harsh but I can't see the point of this table. Aside that its full of errors, what's the point of listing a few old and some newer scope models in their basic specs? You'll probably find more relevant information by 30 seconds of googling.
The following users thanked this post: Priestblood
Offline nctnico
« Reply #7 on: May 22, 2015, 05:34:33 pm »
I didn't knew about the Yokogawa models...
Offline miguelvp
« Reply #8 on: May 22, 2015, 05:39:19 pm »
I thought the Rigol DS2000 series did have segmented memory, I've never used that feature so I don't know for sure.
The following users thanked this post: binary01
Offline pascal_sweden
  • Country: no
« Reply #9 on: May 22, 2015, 05:41:27 pm »
Yokogawa is nice, but expensive.
I like the vertical setup, where the screen is on top of the controls.
So the scope works for both left-handed and right-handed people.
  • Country: jp
    • YouTube Channel
« Reply #10 on: May 22, 2015, 11:10:57 pm »
It took me nearly two weeks to get to this point of chart, who never owned an oscilloscope and did not know what to look for comparing them from many models.
It is good if you could fine it Google in 30 sec by yourself, but it was not for me, so I thought there are some other people like me  :)
I would like to know where is the errors, that was one of the point wanted to have as feedback.
The reason of having some old model is that for example Tektronix TDS5000 series was one of the standard in the past, so I wanted to know how newer models are doing compared to it.
And also having a idea to find good models on the internet auction. ;D
  • Country: jp
    • YouTube Channel
« Reply #11 on: May 22, 2015, 11:15:51 pm »
Agilent/Keysight 2002A started make me as a attractive choice after I made the chart  :)
« Last Edit: May 22, 2015, 11:23:01 pm by fanOfeeDIY »
  • Country: jp
    • YouTube Channel
« Reply #12 on: May 22, 2015, 11:20:08 pm »
I really would like to know whether Rigol DS2000 series have segmented memory or not  :)
I will update the chart.
Offline videobruce
« Reply #13 on: May 23, 2015, 12:32:11 am »
Compiling a chart as this is not just time consuming, it's a nightmare as it's very easy to mix specs up or enter incorrect numbers. I know because I have complied charts for spectrum analyzers and consumer DVR's. It sure as hell isn't easy.
Instead of being "harsh", why not correct some of the errors that you see??  ;)
Offline videobruce
« Reply #14 on: May 23, 2015, 12:35:06 am »
fanOfeeDIY;
What software (program) did you comply the chart on? I have to assume it is a spreadsheet. if so, can you post that instead. The .jpg is hard to read since the mosquito noise is noticeable.  ;)
Great job for starters. I'm sure owners of specific units will chime in and correct any errors.
As a suggestion, I would try to keep a specific price range, instead of as wide of a range as you have. Placing a $400 scope in the same chart with a $14,00 isn't realistic.
« Last Edit: May 23, 2015, 12:41:15 am by videobruce »
Offline Stupid Beard
« Reply #15 on: May 23, 2015, 12:38:02 am »
It does have segmented memory, but it calls it record/replay. The 1000Z series has it also as an option.
Offline miguelvp
« Reply #16 on: May 23, 2015, 01:22:04 am »
It does support segmented memory.
If you zoom in and set the trigger you can adjust the memory depth or leave it at auto and it will show how points it will use per capture the more you zoom in the less points per segment. Of course you can set the memory depth manually.
So I did setup my scope to 500 ns per division capturing the rise time of the 1KHz test signal from the scope, and I only want to capture that rise time and don't care about the rest of the wave.
Mem Depth set to auto selects 14,000 points per capture and if I press the record button then I get 8128 captures of just that.
If however I set it to 56,000,000 points then I can only capture 2 frames but with a ton points before and after the region of interest (trigger point).
So it depends how you set the trigger, for example if you want to capture a glitch you can setup the scope so it only triggers on the glitch and you'll end up with a ton of those glitches to analyze, also by adjusting the mem depth you can get more points before and after the glitch if you need that data to analyze the glitch.
More details in a review by mjlorton: Edit: it starts at 4:48 tried to get the link to start there but the embedded one starts a little early)
« Last Edit: May 23, 2015, 01:26:06 am by miguelvp »
The following users thanked this post: Pizzalover
Offline tautech
« Reply #17 on: May 23, 2015, 02:35:53 am »
I attached the cart comparing the many well known digital Oscilloscopes in the market.
:wtf:  :o
You have omitted a very well known brand, popular with members here: Siglent.
http://siglentamerica.com/pd.aspx?tid=1&T=1
There are several others that are also worthy of inclusion for ANY list to be considered accurate.  ;)
Avid Rabid Hobbyist
  • Country: jp
    • YouTube Channel
« Reply #18 on: May 23, 2015, 03:07:11 am »
Thank you for your all the comments, I attached my excel file at the moment.  :)
I would like to update it with correcting errors later
EDIT
I decided to add excel file at the first comment on this thread
« Last Edit: May 28, 2015, 01:11:34 pm by fanOfeeDIY »
Offline videobruce
« Reply #19 on: May 23, 2015, 10:08:29 am »
fanOfeeDIY;
Three suggestions;
1. You should be able to edit your first posts. It would make things easier if the charts stay there so one doesn't have to wade through what should be a long thread,
2. Swap the columns with the lines since you do not have as near as many specs vs models. That would make it easier to read. Trading width for height. In other words. list the manufactures on the left and the specs across the top,
3. Sort by price and put the disco'ed models at the end (bottom if you do the swap).
BTW, your jpg's look much better, no (or little) mosquito noise.  ;)
  • Country: jp
    • YouTube Channel
« Reply #20 on: May 23, 2015, 11:50:53 am »
Thank you for the comments.
I just changed all the jpg files to png to reduce the misquote noise.
Re-sorting by price, let me work on it tomorrow. :)
Offline rs20
« Reply #21 on: May 23, 2015, 12:09:27 pm »
Maybe I'll be derided as a Google fanboy, but you could post this on Google Drive and make it publically accessible + commentable.
-- It'll be as easy to navigate as Excel, but not require a download
-- People can comment on errors for you, anyone will be able to see those comments straight away, and it'll be much easier for you to address because the comments will be attached to the cells in question
-- You can give temporary/permanent edit permissions to anyone who wants to fix a whole bunch of errors
Edit: Just like this.
Offline Muxr
« Reply #22 on: May 23, 2015, 03:29:37 pm »
I support this effort. I would however add Owon as well, it is the other "big" Chinese brand. Goes something like Rigol, Siglent, Owon. There is also GW-Instek and Hantek.
Also:
Iwatsu - Japanese
and
Hameg or Rohde & Schwarz (how they are called now) - is the big European brand.
« Last Edit: May 23, 2015, 03:32:28 pm by Muxr »
The following users thanked this post: BetterAndBetter
Offline videobruce
« Reply #23 on: May 23, 2015, 03:32:52 pm »
rs20;
Problem with that is it takes away from this forum as in a benefit for the members. IOW's it's just another reason to visit here.  ;)
For that monstrous multimeter chart. That is grossly overwhelming.  Too much info. I can't even imagine who long it took to compose all of that.  :o
Offline videobruce
« Reply #24 on: May 23, 2015, 03:40:58 pm »
fanOfeeDIY;
Looking better. Those manufactures Muxr gave should be included.  :-+
Additional suggestions;
Choose a ceiling price. Say under $2000.US (open for discussion). With the amount of choices out there that should provide enough choices and remove those higher end models, especially above $5k.
Take a look through this sub-forum and note the scopes that have their own threads and ones that get mentioned a lot.
