Am having digital oscilloscope owon sds1104.
-When i save my waveform into my usb-storage(not internal storage of scope), it only saves in ".bin" format. Is there a way i can change this format from bin to say csv.
-Also is there a software that i can use to analysis the waveform i've saved in my usb-storage, whether the format of the waveform is bin or csv or any other?
NOTE: I TRIED THE SOFTWARE PROVIDED IN THE CD-ROM BY OWON. THE ISSUE I HAVE WITH IT IS THAT, WHEN YOU SELECT "data table", THE TABLE DOES NOT SHOW THE TIME CORRESPONDING TO THE VOLTAGE DATA-POINTS. Is there a fix for this?
Thanks in advance
