If you need that, you are probably doing something wrong.
Closest in functionality would be a Logic Analyzer (LA).
Though attaching extra probes on a DDR bus would probably alter the signals too much to be of any relevance in debugging. However, if you still want to try that with a logic analyzer, there are some models that can sample at 400MSa/s on 4 bits, or at 200MSa/s on 8 bits, e.g. the
DSLogic Plus, but no matter wich logic analyzer would be used, 100MB/s means more than 800Mbit/s, while USB2.0 max speed is 480Mbit/s, so there will be no USB2.0 streaming possible at 100MB or 200MB.
Might be possible for an LA to stream over USB3.0, doubt there would be any affordable USB3.0 LA, because in practice there is not much need of such an LA. At high speed it is not trivial to guess the delays through the wires of a parallel bus, so connecting 8 parallel channels of such an LA to a DDR bus would be quite a stunt.
