Author Topic: BK Precision 4017B DDS Function Generator  (Read 2724 times)
Offline elliottTopic starter
« on: July 10, 2013, 06:40:15 am »
I just put a best offer on a BK 4017B function generator on eBay and got it. It seems like a good general purpose function generator, I don't need much, just more than the old home-built opamp generator can give. I had been bidding on some non-DDS function generators, even the older BK 4017, but this wasn't going for that much more.
Does anyone have any experience with these? Not a whole lot of information out there on them.
« Last Edit: July 10, 2013, 06:43:06 am by elliott »
Re: BK Precision 4017B DDS Function Generator
« Reply #1 on: July 13, 2013, 07:22:25 am »
I just got the function generator today and the 50 ohm output fuse is blown, it is a little SMD fuse with the marking F250 on it, which I assume is just voltage and gives me no useful information. I can't find a service manual for it, but I did email BK and asked if they could tell me the value of the fuses.
If BK doesn't respond, I'm going to have to determine a replacement for myself, would I be wrong in thinking that 0.2A would be appropriate since the output is 10V and 50 ohms?
Offline david77
« Reply #2 on: July 13, 2013, 07:39:28 am »
F250 means Fast blow 250mA, so your assumption is more or less correct.
« Reply #3 on: July 13, 2013, 08:20:55 am »
Makes sense, I was just assuming it was voltage because 250V is very common in fuses. I was also assuming the outputs would be fused differently, though that is based on no prior experience.
I need to find some kind of cheat sheet for SMD markings, I'm so used to through hole.
Thanks, now I just need to measure the thing so I get the right size.
Offline ve7xen
    • VE7XEN Blog
« Reply #4 on: July 13, 2013, 09:20:45 am »
Probably a good idea to get replacement devices for the output stage at the same time. Chances are pretty good the fuse didn't save them...
73 de VE7XEN
He/Him
« Reply #5 on: July 13, 2013, 09:30:03 am »
It appears to be outputting fine up to the fuse, just not through it, I didn't put a load on it though.
