Sorry for the slow reply, been busy with another snow storm.
So, the two meters I'm most concerned with are my Brymen BM786 and my Siglent SDM3055. They are supposed to be my "best" two meters but they are the furthest apart in their readings. All my cheaper meters fall in between. So, I have no idea which is correct or if they are both wrong and nothing to calibrate them against.
In these pictures, the two meters have been on for 30 minutes with two supposedly identical probes just dangling beside each other in the air. If I exchange the probes (or use entirely different probes) the results are the same. Maybe a .3 degree difference from what you see here.
