Author Topic: DHO 900 series USB hub  (Read 844 times)
Offline GadjetTopic starter
    • My Blog
« on: September 02, 2024, 06:21:46 pm »
I have just bought a DHO914 scope and really like it so far but the lack of WiFi is a pain, I found the hacks to get it working with a WiFi dongle but I'd like to use a USB memory stick and possibly a mouse as well all at the same time.
So I've designed a custom USB hub shaped for the DHO900 series that I hope will work with the logic analyser plugged in at the same time.
Here is a picture of the case for the hub (the electronics are on order) and I was wondering if anyone who has the logic analyser module could give me an idea if you think it will still plug in with this USB hub fitted
I have a design also for the DHO800 series that would cover the socket for the logic analyser.
The following users thanked this post: kd7eir
Offline ebastler
Re: DHO 900 series USB hub
« Reply #1 on: September 02, 2024, 06:33:36 pm »
Yes, it will fit -- the plug of the PLA2216 logic analyser is not wider than the cutout in the scope's front panel. It may be a bit of a fumble to pull the plug out again while the USB hub is installed, since you can't get a good grip. But you are not supposed to hot-plug (or unplug) the logic analyzer anyway.
The following users thanked this post: Gadjet
Offline Fungus
« Reply #2 on: September 02, 2024, 09:07:16 pm »
Get the files over FTP once you have WiFi working.
Buy a stylus instead of using a mouse.
    • My Blog
« Reply #3 on: September 02, 2024, 09:45:51 pm »
That would mean having the scope within arms reach  :-\
