Hi, gang,
I just opened my DE-5000 and turned it on. So far, so good. It came with the SMD tweezers, two "guard wires" with banana plugs, but no TL-21 clip lead module. I think I knew this when I bought it on sale 1-2 years ago from a seller in Japan.
I was delayed in the unboxing by flood recovery and two surgeries. Life happens when you're not test equipping.
Anyhoo, I'm wondering if I can make a clip lead adapter from coax (or shielded wire) and banana plugs until I find a TL-21 that's somewhat reasonably priced?
I see that the blade sockets and the banana plug sockets are connected. I assume that the guard socket would connect to the test clip shield cable and that each remaining plug socket would connect to its own gator clip? Or maybe each clip gets its own short length of shielded lead wire with shield to guard and test point to test clip?
I did measure a few caps by using the long guard plugs/clips with the test sockets, calibrating out the 3 pF or so lead capacitance from the long bundle of test wires. Seemed to work on anything but a 2 pF mica cap.
At present I'm not overly concerned with the many discussions of whether this meter suxx or not, etc. It's the tool I have, and at present, the tool I need to use.
I have a separate ESR meter and a separate low/high voltage cap leakage measuring device.
I am not a rocket surgeon with most test gear, but I'm working on it.
As always, your help is appreciated,
--NT0Z
