Author Topic: Rigol DG1022Z harmonic setting bug?  (Read 657 times)
Offline CirclotronTopic starter
« on: August 10, 2020, 02:13:16 am »
I generate a 400Hz sinewave on channel 2 at 2mV p/p. The minimum.  Then I turn on the 4th harmonic and H4 goes to 1.2v p/p and you can’t change the amplitude. In fact, sitting at the fundamental, if you go to any harmonic of 4 or greater the 4th harmonic comes on like this and the higher harmonic stays at zero V and can’t be adjusted. The only way you can turn of H4 is to go to H3 or lower. Firmware is 03.01.12 (latest available version)
« Last Edit: August 11, 2020, 03:12:13 am by Circlotron »
Re: Rigol DG1022Z harmonic setting bug?
« Reply #1 on: August 24, 2020, 06:42:23 am »
Bump for a new set of eyes.
