Author Topic: DIY Logic Analyzer Probe and Pods for Siglent (and LeCroy) scopes  (Read 147172 times)
0 Members and 25 Guests are viewing this topic.
Offline MathWizard
Re: DIY Logic Analyzer Probe and Pods for Siglent (and LeCroy) scopes
« Reply #250 on: November 12, 2024, 03:56:17 am »
Yeah I'm just trying to get it working with what I have. I ordered a DreamSoucre DSLogic U3Pro32 Friday.
But hey I got it working, it really was that the PCI-E connector was a few tenths of a mm too thick, with the added solder/wires. The contact is still not great, not every time anyways.
Here a picture of some audio channel, and volume control data, that I'm bare-metal coding onto an ATtiny13A, to fix my stereo.
And here's a 3.3V 25MHz square wave from my SDG2142X, either triggered from CH2 or D7, which is the farthest from the data probe GND pin.
And my CH2 scope probe has the big long GND lead, and I'm just clipped on a few cm away from the series 360R resistor I probed, before it enters the scope. So the signal's probably a bit better than it looks.
« Last Edit: November 12, 2024, 04:09:19 am by MathWizard »
The following users thanked this post: egonotto, KungFuJosh
Offline rb720
DIY Logic Analyzer Probe with SDS2204X HD
« Reply #251 on: January 21, 2025, 07:47:15 pm »
I'm about to purchase a SDS2204X HD. Will this DIY probe work with it, or is the software locked? I probably only need low frequency use, so the DIY probe could make sense for now, could buy the SPL2016 later if I need more bandwidth/precision.
Offline tautech
Re: DIY Logic Analyzer Probe with SDS2204X HD
« Reply #252 on: January 21, 2025, 08:20:22 pm »
MSO licensing for all DSO's that support it has been abolished in recent firmware.
This allows one MSO probe to be used on any scope that supports it.
Avid Rabid Hobbyist
Offline rb720
« Reply #253 on: January 21, 2025, 10:17:57 pm »
Thanks for the info, placed the order today with Saelig. They gave a 5% discount for reading the eevblog.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #254 on: November 03, 2025, 12:30:35 pm »
Has anyone tried this with coax cable like this?
Would it work as-is, or require a different set of capacitors and resistors?
https://www.aliexpress.com/item/1005005981763537.html
I'm also thinking of getting some of these clips, they look like clones of the old Tek type, but in nice colours.
https://www.aliexpress.com/item/1005008554552656.html
Offline BillB
« Reply #255 on: January 21, 2026, 03:20:19 pm »
A bit late to this game but am looking into LA probe options for an SDS2104X+.  Has anyone seen or have any experience with this one?
eBay auction: #375653175323
It's sure seems to be a copy of oz2cpu's design, given that it seems to use his image he posted in this thread of the first test!  I can't tell from the images if it's a 2 or 4 layer PCB, and the use of the twisted ribbon rather than coax is kinda a turn-off.  That being said, the price is a little more tolerable for me.  I'm a little too time and skill constrained to embark on my own DIY version.
Offline mawyatt
« Reply #256 on: January 21, 2026, 04:28:45 pm »
First check with oz2cpu (Thomas) to see if this copy is approved, he may have some that he will sell.
Best
~Wyatt Labs by Mike~
The following users thanked this post: oz2cpu
Offline affe00
  • Country: cn
« Reply #257 on: July 19, 2026, 08:09:15 am »
hello,
I'm very much appreciative to your discussions before! Based on the information here in this topic, I had my proposal, and I wish to know your comments.
my proposal is this:
pci-e socket on scope <=> PCB board with 16x I-PEX MHF 4L receptacles <=> 150mm micro-coax wire with MHF 4L plug / SMA socket
<=> 300mm RG316 wire with SMA plugs <=> tiny, single channel PCB, with 250\$\Omega\$ + 90.9k//8.2pF, SMA socket on one end , 2.54mm pins on the other end.
the tiny single channel PCB board can be then protected with PI tape and heat shrink tube.
the good things about this proposal are: 1) micro-coax cable and RG316 cable. 2) channels can be attached/removed as needed.
Any comment, please?
I also wish to know how the resisor/capacitor values may be tuned to better suit the 50-ohm coax cables?
thank you!
Offline oz2cpuTopic starter
    • webx.dk private hobby and diy stuff
« Reply #258 on: July 19, 2026, 08:38:59 am »
Hi Affe
I am happy someone keep playing with this, I am still very happy about mine.
The answer : you can not do any of this,
this probe design NEED high impedance twisted pair cables,
they are cheap thin flexible and easy to work with,
no need to change or modify this import part of the project
Radioamateur call sign OZ2CPU, Thomas Scherrer, Senior EE at Prevas, EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline cbpoulsen
« Reply #259 on: September 27, 2026, 08:17:07 pm »
Designing a DIY MSO probe for the Siglent SDS2000X Plus series: the theory
The SDS2000X Plus oscilloscopes can show sixteen logic channels next to their analog traces, but only through Siglent's SPL2016 logic probe. Several people have built their own probe instead, and the EEVblog forum holds a long and generous thread on how. This article is not a build guide. It explains the electrical ideas behind such a probe: what the scope expects at its logic input, why the tip carries a resistive divider of about 11:1, how that divider is compensated, what the cable does at nanosecond timescales, and how to check the result with nothing but the scope.
Along the way it compares the author's design with two published community designs, and it points out one tempting addition, a resistor to ground at the scope end, that looks like good practice and quietly halves every threshold on the screen.
(The photo, Figure 1, is attached at the bottom of this post.)
Figure 1. The author's probe on an SDS2104X Plus: 3M twisted-pair flat cable, 3D-printed plug shell and two eight-channel pods, with D0 on the 1 kHz calibrator.
1. What the scope expects from its probe
The models in the SDS2000X Plus series, from 100 MHz to 500 MHz, share the same logic-analyzer input and the same SPL2016 probe. The author's measurements were made on an SDS2104X Plus. Any of them turns into a 16-channel mixed-signal oscilloscope when a logic probe is plugged into the slot marked D0–D15 on the front panel. The slot is mechanically a PCIe x1 edge connector, but electrically it has nothing to do with PCI Express: 16 signal pins, each flanked by ground pins, feed 16 comparators inside the scope.
Siglent's own probe, the SPL2016, is specified as:
ParameterSPL2016
Input impedance at the tip100 kΩ ‖ ~18 pF
Input dynamic range±20 V
Threshold range±10 V, 10 mV steps
Threshold presetsTTL 1.5 V, CMOS 2.5 V, LVCMOS 3.3 V (1.65 V), LVCMOS 2.5 V (1.25 V)
Minimum input swing800 mVpp
Maximum data rate300 Mbit/s
Threshold groupsD0–D7 and D8–D15
The numbers that matter for a DIY design are not printed there, because they are properties of the scope, not of the probe:
1. The thresholds you set are tip voltages. The comparators never see 1.65 V; they see about an eleventh of it. The firmware scales your threshold setting down by the ratio of Siglent's probe before it programs the comparator reference. A home-made probe therefore has to divide by the same ratio, or every threshold on the screen is wrong by the same factor.
2. The scope supplies part of the divider. A genuine SPL2016 measures 91.1 kΩ from tip to edge connector (tautech, EEVblog). Measured into the scope's LA pins, the input is about 9 kΩ to ground: the author reads 9.11 kΩ on a powered SDS2104X Plus with a Fluke 179, mawyatt measured ~8.6 kΩ with a resistive divider, and OZ2CPU's trimming implies ~9.6 kΩ. 91 kΩ over ~9.1 kΩ is a divider of about 11:1, and the sum is the datasheet's 100 kΩ. The ratio is usually called 10:1 by habit, but with the bottom leg inside the scope the arithmetic gives 11:1, and that appears to be what Siglent's own probe does too. It looks very much as if Siglent's 90.9 kΩ / 9.09 kΩ pair is split between the probe and the instrument. The bottom leg of the divider lives inside the oscilloscope.
3. The comparators have hysteresis. DL2XY reports roughly 650 mV of hysteresis referred to the tip. That is generous, and it is why a correctly divided probe hardly ever chatters on slow edges, but it also means "the threshold" is really a band 0.65 V wide centred on the setting.
The rest of the design follows from these three facts.
2. Why attenuate at the tip at all
A logic probe could in principle be a bundle of wires straight to the comparators. Every serious logic-analyzer probe since the 1980s has instead put a large resistor right at the tip, and the reasons still apply:
  • Loading. A comparator input with its protection network is a few kΩ and several pF. Hung directly on an I²C line with 4.7 kΩ pull-ups, or on the output of a weak oscillator, that load changes the circuit you are trying to observe. 100 kΩ at the tip is loading an engineer can ignore in most digital circuits.
  • Overvoltage. With ~91 kΩ in series, a tip accidentally touching 24 V or a gate-driver rail delivers a fraction of a milliamp into the protection diodes. Without it, the same slip drives the scope's ESD structures directly.
  • Range and resolution. The comparator reference covers a little under ±1 V. Scaled up by the probe's ratio, that becomes the useful ±10 V threshold range on the screen, with 10 mV steps at the tip.
  • Capacitance. The tip resistor is bridged by a small capacitor (5.6 pF in the author's probe, 8.2 pF in the classic HP-derived designs). Seen from the circuit under test, the probe is then that few pF in series with everything behind it, rather than the whole cable. That only works if the divider is compensated, which is the next topic.
3. Compensation: the same rule as a ×10 scope probe
A resistive divider with stray capacitance on its bottom leg is a low-pass filter with a time constant in the hundreds of nanoseconds, which is useless for logic signals. The cure is the one every ×10 passive probe uses: bridge the top resistor with a capacitor so that the divider is capacitive at high frequency and resistive at low frequency, and choose the capacitor so that both ratios are the same.
The divider is flat (frequency independent) when
R_top · C_top = R_bot · C_bot
Put numbers on it. With 90.9 kΩ and 5.6 pF at the tip, R·C = 509 ns. If the bottom leg is the scope's ~9.1 kΩ, the bottom capacitance must be about 55 pF. That capacitance is not a component; it is the sum of
  • the cable, which at low frequency behaves as a lumped capacitor (3M 1700-series twisted-pair flat cable: 52 pF/m signal-to-grounds, 44 pF/m within a pair; half a metre is roughly 22 to 26 pF),
  • the plug PCB traces and edge connector,
  • the scope's input capacitance behind the connector, which Siglent does not publish.
For OZ2CPU's values, 86.6 kΩ × 8.2 pF = 710 ns, asking for about 74 pF across the bottom leg. The differences between 5.6 pF and 8.2 pF designs are mostly differences in cable length and cable type.
What goes wrong when the rule is not met is subtle on a logic channel, because there is no trace on the screen to show overshoot or droop. Instead the error appears as timing:
  • Under-compensated (C_top too small): the fast part of the edge is attenuated more than the DC ratio, and the signal creeps up to its final value over a few hundred nanoseconds. The comparator switches late, and later still at thresholds close to the logic high level. Narrow pulses shrink or disappear.
  • Over-compensated (C_top too large): the edge overshoots and then sags. The comparator switches early, and a threshold placed near the top of the signal can produce a short glitch.
Both show up as a duty cycle that changes when you move the threshold. That gives a practical test: feed a clean square wave, measure its duty cycle with the scope's digital measurements, and sweep the threshold from 20 % to 80 % of the signal amplitude. A compensated probe gives the same duty cycle across the sweep.
Use C0G/NP0 capacitors. At 5.6 pF, the voltage and temperature coefficients of X7R would move the compensation around by tens of percent.
4. The cable is a transmission line
Half a metre of cable is about 2.7 ns of delay (3M 1700 series: 5.35 ns/m, velocity factor 0.62). A logic edge from a modern CMOS part rises in 1 to 2 ns, shorter than the round trip down the cable and back. For those edges the cable is not a capacitor but a transmission line, and the design has to decide what happens to the reflections.
Pairing. In the author's probe every signal conductor in the 16-way 3M 1700/16 cable is twisted with its own ground conductor, eight pairs per pod. Each channel is then a balanced pair with a characteristic impedance of about 122 Ω, its own return path, and a small loop area. Crosstalk between channels drops sharply compared with a plain ribbon where eight signals share one or two grounds, and the return current of each edge flows right next to its signal.
The receiving end is effectively open. The scope end presents about 9 kΩ, a hundred times the cable impedance. An edge arriving there reflects with almost the full amplitude and travels back towards the tip.
The series resistors. Both the pod and the plug carry a 121 Ω resistor in series with each signal (120 Ω in OZ2CPU's design, 250 Ω and 370 Ω in mawyatt's sketch). They are not terminators in the usual sense, because neither end is a matched load, but they do two jobs:
  • At the tip end, 121 Ω in series with the 5.6 pF compensation capacitor looks, at high frequency, like a source impedance close to the cable impedance. The reflection coming back from the open far end is absorbed there instead of bouncing back again. This is series (back) termination, the same technique used on fast PCB traces.
  • At the scope end, 121 Ω isolates the line from the comparator's input capacitance and protection network, damping the ringing that a capacitive load at the end of a line produces.
The value is chosen to match the cable, which is why the author picked 121 Ω (E96) for a 122 Ω balanced pair, and why OZ2CPU notes that coax builds need around 75 Ω. The combined effect is a step at the comparator that settles within one round trip and crosses the threshold once.
Why not coax. The SPL2016 itself uses a multi-coax cable (about 45 Ω, 6.1 ns for 1.1 m). Coax gives the best isolation between channels but is expensive in 16-way form and stiff; twisted-pair flat cable is a very good compromise for the half-metre lengths a bench probe needs, and it is available off the reel.
(continued in the next post)
« Last Edit: September 28, 2026, 08:18:40 am by cbpoulsen »
Offline cbpoulsen
« Reply #260 on: September 27, 2026, 08:18:17 pm »
Designing a DIY MSO probe for the Siglent SDS2000X Plus series, part 2
5. The design with optional capacitors
Mike Wyatt (mawyatt on EEVblog) drew up a "logic analyzer base" for the scope end in March 2021 with every value marked TBD: a series resistor, a resistor to ground, a capacitor to ground on the scope side of the resistor, and a second capacitor to ground on the cable side. His pencil sketch of the full chain gives starting values: 250 Ω and 90.9 kΩ ‖ 8.2 pF in the pod; 370 Ω series, 7.4 pF "including DSO capacitance and connector" and 1.5 pF "including pad capacitance" in the base.
The two capacitors are there for different reasons:
  • The scope-side capacitor is the bottom half of the compensation. Section 3 showed that the bottom leg needs a definite capacitance for the divider to be flat. Some of it comes from the cable and the scope. The rest has to be added, and how much depends on cable length, cable type and the scope model. A footprint for a fixed capacitor lets the builder close the gap without trimmers, which would be impractical on sixteen channels.
  • The cable-side capacitor trims the line's end. A pF or two at the point where the twisted pair meets the PCB shapes the discontinuity there and can reduce overshoot on the fastest edges. It is a fine-tuning option rather than a necessity.
"Optional" is the key word. The base is best read as a flexible platform: populate nothing and it behaves like the simpler designs; populate the capacitors and it can be tuned to a particular cable and scope. The cost is that the builder has to measure and choose, which the fixed-value designs avoid by picking values that work for a known cable length.
6. Checking a finished probe
Two simple tests cover the theory above and need nothing more than the scope itself.
Divider ratio (threshold test). Connect one channel to the scope's 1 kHz calibrator output and step the custom threshold for that group up and down until the channel stops toggling. The channel toggles only while the threshold, as the scope understands it, lies inside the signal's swing. With a correctly matched probe that window spans roughly the calibrator's full amplitude. If it spans about half of it, the probe divides by twenty and every threshold on the screen is half the real one.
The author's probe toggles on the 3 V calibrator for any threshold from 0.06 V to 3.1 V: the full swing, within the scope's specified threshold accuracy of ±(3 % + 200 mV). It also triggers correctly with every preset: TTL, CMOS, LVCMOS 3.3 V and LVCMOS 2.5 V. A probe that divides by twenty would lose the signal already at about 1.5 V, and the 2.5 V CMOS preset would fail on a 3 V signal.
Threshold accuracy (DC test). For a closer look, set a threshold, feed the channel a slowly adjustable DC level from the scope's AWG, and note where the channel switches going up and going down. On the author's probe, a 1.00 V setting switches at 0.93 V rising and 0.91 V falling, and a 2.00 V setting at 1.9 V and 1.8 V. Both switch at about 0.92 of the set value, so it is a scale (gain) error of about 8 %, not an offset. That is well within the ±(3 % + 200 mV) specification at logic levels and makes no practical difference.
Compensation (duty-cycle test). Feed a square wave with fast edges, for example a 74HC-family gate clocked at a few MHz, and read the duty cycle while stepping the threshold across the signal. Constant duty cycle means a flat divider. Duty cycle that grows or shrinks with threshold means the tip capacitor is too small or too large for the cable and scope behind it.
The ohmmeter also helps, with one caution. With the probe unplugged, each channel should read the tip resistor plus the two series resistors from tip to plug pin, and open circuit between neighbouring conductors. Plugged in, a reading from tip to ground includes the scope's internal bottom leg, but it is measured through the scope's ESD diodes and bias network, so it changes with test-lead polarity and with whether the scope is powered. It is useful for spotting a broken channel, not for measuring the divider ratio; the threshold test does that better.
7. Three designs and the bottom leg
The three designs discussed here differ mainly in how they treat the bottom leg of the divider, the part that is already inside the scope.
OZ2CPU (Thomas Scherrer). The design most builders have used: 120 Ω and 86.6 kΩ ‖ 8.2 pF in the pod, 50 cm of twisted pair, and only a 120 Ω series resistor on a four-layer plug board. At first sight it looks unattenuated, since nothing at the scope end goes to ground. It is not: the scope's own input resistance is the bottom leg, exactly as in Siglent's probe. Thomas arrived at 86.6 kΩ empirically, trimming a channel from 100 kΩ until the switching point matched a known 4.9 V signal, which is a measurement of the scope's internal resistor by another route.
mawyatt (Mike Wyatt). A base board with every value left to be chosen, including the two optional capacitors discussed in section 5. It is the most flexible of the three and the most explicit about compensation. Its resistor-to-ground position is the one to be careful with on this scope: it sits in parallel with the internal bottom leg, so it has to stay empty, or be very large, if the ratio is to stay at about 11:1.
The author's design. 90.9 kΩ ‖ 5.6 pF C0G at the tip, 121 Ω at both ends of a 3M 1700/16 cable with every signal twisted with its own ground, and nothing to ground on the plug board. The 90.9 kΩ is the E96 value closest to the 91.1 kΩ measured in a genuine SPL2016, so the probe presents the same DC load as the original; the 121 Ω resistors are matched to the 122 Ω balanced impedance of the pairs; and the 5.6 pF calls for about 55 pF across the bottom leg. Half a metre of this cable supplies roughly half of that; the rest has to come from the plug board, the edge connector and the scope's input, whose capacitance Siglent does not specify, so the duty-cycle test in section 6 is the final judge. The threshold test confirms the ratio (section 6).
(The schematic, Figure 2, is attached at the bottom of this post.)
Figure 2. One channel of the author's probe as modelled in KiCad. R5 and C2 inside the box stand for the scope's own input resistance and the capacitance the compensation calls for; they are not parts on the plug board.
The tempting resistor to ground. A textbook divider has two resistors, and it is natural to draw the second one, 9.09 kΩ to ground, on the plug board. On an SDS2000X Plus that resistor sits in parallel with the scope's own ~9.1 kΩ, the bottom leg falls to about 4.5 kΩ and the ratio becomes about 21:1. Every threshold on the screen is then half the real one, the CMOS (2.5 V) preset stops working on 3.3 V logic, and the compensation needs twice the bottom capacitance. A probe and the input it plugs into are one circuit, and the half inside the instrument is easy to leave out of a schematic or a simulation.
Choosing the tip resistor. The top resistor has to be about ten times the scope's internal resistance, which gives the same 11:1 as Siglent's probe. OZ2CPU's 86.6 kΩ (about 10.5:1) and the author's 90.9 kΩ (about 11:1) both land within the scope's threshold accuracy. Builders using other cables or plug boards can use the same method: run the threshold test, choose the E96 value that makes the window span the full calibrator amplitude, then change the tip capacitor in inverse proportion so that R·C at the tip stays the same.
8. Summary
  • The SDS2000X Plus logic input contains the bottom leg of the divider, about 9.1 kΩ to ground. The probe supplies the top leg, about 91 kΩ, and nothing else to ground, giving about 11:1 and 100 kΩ like Siglent's own probe.
  • The firmware assumes the ratio of Siglent's probe. Any other ratio shifts every threshold by the same factor; the author measured the scale to be about 8 % low, which is harmless for logic levels.
  • The tip resistor is bridged by a few pF of C0G so that R·C matches the capacitance of cable, connector and scope on the bottom leg. A mismatch shows up as a duty cycle that depends on the threshold.
  • For modern edges the cable is a transmission line. Twisted pairs with one ground per signal, and series resistors close to the pair impedance at both ends, give clean single crossings.
  • Two tests with the scope's own calibrator check a finished probe: the threshold window for the ratio, and duty cycle against threshold for the compensation.
Credits and sources
This work leans on the people who worked it out in public first. Thomas Scherrer (OZ2CPU) designed and shared the probe most DIY builders use. Mike Wyatt (mawyatt) contributed the transmission-line modelling and the flexible base design. tautech, DL2XY and many others in the EEVblog thread measured the original probe and the scope. Any errors here are mine.
  • Siglent SPL2016 datasheet (probe specifications).
  • 3M 1700-series twisted-pair flat cable datasheets TS0115 and TS0308.
  • EEVblog forum, "DIY logic analyzer probe and pods for Siglent scopes": measurements by tautech (91.1 kΩ), mawyatt (~8.6 kΩ), DL2XY (~650 mV hysteresis) and OZ2CPU's threshold trimming.
  • OZ2CPU (Thomas Scherrer), "Siglent SDS Scope Logic Analyzer DIY parts", Thingiverse 4784443, V1.0 and V2.0 schematics (CC BY-NC-ND).
  • Mike Wyatt (Wyatt Labs), "Logic Analyzer Base" schematic and hand sketches, March 2021.
  • The author's KiCad project spl2016 (probe, plug and model sheets) and bench measurements on an SDS2104X Plus.
« Last Edit: September 28, 2026, 08:19:12 am by cbpoulsen »
Offline cbpoulsen
« Reply #261 on: September 28, 2026, 08:50:32 am »
Correction: I have just edited my two posts above. The divider is 11:1, not 10:1. The resistors are in a 10:1 ratio (90.9 kΩ in the tip, about 9.1 kΩ inside the scope), but the input voltage is shared across both, so it divides by (90.9 + 9.1) / 9.1 ≈ 11.
I checked it on my SDS2104X Plus with DC from the AWG: with the threshold set to 1.00 V, the D channel switches at about 0.92 V at the probe tip, and at 2.00 V at about 1.85 V. That's roughly 8 % low, well inside the SPL2016's specified threshold accuracy of ±(3 % + 200 mV), so it's harmless for logic levels.
Thanks for reading, and corrections are welcome.
« Last Edit: September 28, 2026, 08:52:25 am by cbpoulsen »
« Reply #262 on: September 28, 2026, 08:56:04 am »
i am happy to hear more people work with the DIY digital input
i still use mine and i am super happy about it
The following users thanked this post: cbpoulsen
Offline cbpoulsen
« Reply #263 on: September 28, 2026, 09:16:59 am »
Thanks, OZ2CPU! Your design was a big inspiration. My aim with the posts was mainly to explain the theory behind the input divider and compensation, so others can understand the trade-offs and adapt a design to their own needs. Good to hear yours is still going strong.
