Products => Test Equipment => Topic started by: coflynn on March 07, 2015, 10:32:03 pm
I wondered if anyone had designed/built their own open-sided TEM cell for basic EMC testing, or otherwise used one? Basically appears to be a few pieces of PCB of appropriate dimensions to form the cell.
As a reference here is a few examples of what I'm talking about:
Commercial small TEM cell - $599, see manual for details (http://tekbox.net/test-equipment/tbtc1-tem-cell)
Atmel article on TEM cell - fairly large (http://www.atmel.com/Images/Article_AC10_Open-TEM-Cells.pdf)
Paper on DIY TEM cell - medium size (http://www.ewh.ieee.org/soc/emcs/acstrial/newsletters/summer08/pp2.pdf)
I was looking at making PCB design that could just be sent to fab, but wondered if someone else had done that? The $600 TEM cell isn't a terrible deal compared to the cost of large PCBs, but it's also maybe a little small for my use.
Regards,
-Colin
One of these days I'm going to do something like that. But why use PCB? I was thinking cardboard, aluminum foil and tape!
Tim
I would like to build a closed tem cell for emc radiated and susceptibility testing. I always thought a open tem cell was some what compromised I.e spewing out e fields and picking up back ground noise. Any one have any experience with these?
would agree, should be closed. am interested as well, so anybody who has done that and wishes to share info would really be appreciated.
I Have collected a number of papers including research on the topic however i have not had any time to review or do anything about it as i am seriously tied up with work.
PM me if you are interested in a copy of what i have collected.
Regards
Bart
We use a commercial open TEM Cell in our lab: http://www.frankoniagroup.com/downloads/EMC_Test_Equipment/tem_cells_open.pdf?PHPSESSID=49625481387bf6978cd99bacc3d6237d (http://www.frankoniagroup.com/downloads/EMC_Test_Equipment/tem_cells_open.pdf?PHPSESSID=49625481387bf6978cd99bacc3d6237d) , though not really low cost. Advantage is that we can monitor displays and LEDs during testing easily.
External noise can be easily identified by powering on/off the DUT
Here a youtube video from the chip whisperer using an open TEM Cell: https://www.youtube.com/watch?v=J_6JA94pE-Y (https://www.youtube.com/watch?v=J_6JA94pE-Y)
Anyone end up making one of these?
Yes. I have designed and build a fully closed TEM cell. But I didn't got to finishing the text yet and the Excel sheet I created to calculate all the sizes needs some tweaking as well. I'm planning to do a very longwinded post about the entire project. Likely I'll need several postings to fit all the text...
