Successful conversion to DL3031A. Model number is shown as DL3031A, no bugs were noticed (did system reset before & after mod). Tested with 350W and 60A loads, all is fine. Thanks to @Pedrofabian for confirmation that hardware is the same for all DL3000 range
To anyone interested in how to do the mod between RIGOL DL3021/3021A/3031/3031A models:
- turn on DL3000 load, make a system reset via menu, stick in prepared USB stick
- connect to DL3000 and open SCPI/serial terminal: via USB (Rigol Ultra Sigma or serial terminal) or via RS232(Rigol Ultra Sigma or serial terminal) or via LXI LAN (telnet or RigolBildschirmkopie)
- enter command "*IDN?" (without quotes, should show current model number - if not, something went wrong in step #2)
- enter command ":PROJ:SET MODEL,DL3031A" (without quotes, model number is from a set {DL3021/DL3021A/DL3031/DL3031A})
- enter command "*IDN?" (without quotes, should show new model number - if not, something went wrong with step #1 or #4)
- restart device, make a system reset
- enjoy
This didn't really work for me. I have a Rigol DL-3021 that I just bought. It has the following firmware versioning shown on the front panel:
Software Version: 00.01.05
FPGA Version: 02.03
Boot Version: 01.011
Hardware Version: 01.00
I attached an RS-232 cable with a DB9 cable from my computer to the DL-3021. After connecting, I could successfully send the "*IDN?" command, and the device returned an appropriate response. So I know the serial communication is working and I have the right baud rate, etc.
Then I tried sending the command ":PROJ:SET MODEL,DL3031A". And the device just hangs with no response.
I tried the same thing using the Rigol's Ultra Sigma software and a USB cable (instead of the RS-232 serial cable). The same thing happened: after sending the "PROJ:SET MODEL,DL3031A" command the devices hangs with no response.
After the device hangs, if I try to type "*IDN?" again, there is no response any more.
The DL-3021 must be power cycled to get the RS-232 port (or USB port) to become responsive again.
I must admit that I don't know what is meant in the above instructions by this: "stick in a prepared USB stick". And there is a link to some topic that is talking about a completely different device (the DP832). Surely I don't want to follow advice for a DP832 on a DL3021? Is there something that needs to be on a USB stick when I run the ":PROJ SET MODEL" command? If so, what?
Is there any other documented way of doing this? This is really the only detailed instructions I could find for doing the upgrade.
