I have the "CSI 2002H" model. I bought it to use it as power supply for small projects which don't require precise voltage/current control (flashing leds for bicycle dynamos, led panels, ...) and it does its job.
I like the fact that you can limit the current before enabling the output. It sounds silly, but I saw cheap bench power supplies which don't display it before enabling the output.
The problem that I found is that if you enable the usb port while using the general output, the voltage switches to 5 volts, it enables the usb supply, but doesn't disable the the general output, so you can fry whatever is connected in case it doesn't tolerate 5 volts. So, it is fine if you care about not to enable the usb port while using the general output.
