I have often wondered how much duplication of test gear does one really need?
I have taken the approach: Do I trust that piece of gear?
How can it be trusted without comparison?
Because of the fear of turning into a "Volt Nut" I have taken this approach:
When the tester is checked against
known value new components and results are within coey, that's good enough IMO.
So for a cap of say 470 uF and 50 mOhm ESR if it measures better than 450 and 70 I will consider it still serviceable.(figures pulled out of the air.
Consider that a properly designed circuit "should" have some tolerance of component values so it can still operate with the tolerance of manufactured components.
Absolute test values are therefore not needed IMO
