Author Topic: 121GW App Testing  (Read 16070 times)
Offline Seppy
  • Curious
Re: 121GW App Testing
« Reply #175 on: September 06, 2018, 04:02:54 am »
The iOS app hasn't had the update released to the store, I don't currently have an iphone on me that I can test the update with... I could just wing it but that seems abit dodgy.
Offline QrackM
  • You can count on me...
« Reply #176 on: September 15, 2019, 07:22:17 pm »
I hope you don't mind bringing this thread from the grave, but it seems to be most appriopriate for my issue:
In Windows app I have Build 65 installed from the Store and while it works, there buttons (graph reset and CSV save) are invisible buttons - is it supposed to be that way?
Best regards,
Offline Seppy
  • Curious
« Reply #177 on: September 16, 2019, 01:54:29 am »
No it shouldn't be invisible. Its possible you maximised the plot.
Try double click on the graph.
Also, do you have a screenshot?
Offline JonM
« Reply #178 on: September 16, 2019, 04:21:11 pm »
Since this thread has come back, what is happening with the iOS update? If it is lack of hardware maybe someone in Australia could send an old iDevice to the mailbag (actually maybe not put 'mailbag' on it so that it does not sit on the shelf for too long...).
Another possibility is to use the TestFlight app and have us users do the testing.
Thanks!
Offline Seppy
  • Curious
« Reply #179 on: September 17, 2019, 01:01:28 am »
Somebody lost the sim that I use to authentic the account developer account.
Might be a way to work around it, not sure.
Offline QrackM
« Reply #180 on: September 17, 2019, 03:08:44 pm »
Hi Seppy,
Thank you for your answer. To make it easier to communicate, I attach screenshot of app window with example of highlighted, but invisible button.
Can this be due to my W10 theme settings (dark)?
Offline Seppy
  • Curious
« Reply #181 on: September 18, 2019, 04:19:42 am »
It could be related. The windows theme affects button colours.
Are you able to type the standard windows light theme for comparison?
Offline QrackM
« Reply #182 on: September 19, 2019, 05:38:56 pm »
Hi Seppy,
With W10 theme set to 'Light' buttons are visible (attached screenshot). This shouldn't be hard to fix given the software project files. If needed, I can have a go with fixing this issue.
Also, from usage perspective, I had trouble to switch between DMM screen/plot/combined display form - now I understand that it is controlled by click and window proportion. Is there any brif help/FAQ for the app available?
Best regards,
Offline firstcolle
« Reply #183 on: September 29, 2020, 06:13:48 pm »
i can't download the app from microsoft store..
any other way to get the app?
thanks
