Author Topic: Do you have any test equipment in your lab that uses vacuum tubes?  (Read 18280 times)
Re: Do you have any test equipment in your lab that uses vacuum tubes?
« Reply #100 on: October 08, 2019, 08:16:30 am »
I have a (newly resurrected, see here -- hp) -- 428b, bought as for-parts from the US. With a probe!  I have wanted it since I read about it in (I think) the -- hp -- 410b service manual.
I do not own a 410b; that auction fell through. This time.
I do own a Marconi TF1041B VTVM of 1968 vintage with the whole shebang including a heated probe, also working.
Finally, an Euratele 412 Abgleichsender, also working. My wife found it for me at the large Eskilstuna ham flea market. Yes, I have the best wife in the world.
The Euratele range was, I understand, something of a German Heathkit, "some" assembly required. It does all then-current broadcast bands, and some more on shortwave. Have verified der Abgleichsender on Band II FM (in Sweden, it is allowed to operate a very, very weak Band II FM transmitter for local perusal), and it apparently works across the house, and probably further if you connect a decent antenna to it.
There will undoubtely be more valve equipment coming my way.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #101 on: October 08, 2019, 03:16:32 pm »
Congratulation to that wife  :)
Don`t forget some of the larger system needs some A for glowing.
When I start here more then 3 from the scopes the fuse of the workroom will stop the job  |O
Martin
« Reply #102 on: October 08, 2019, 06:28:02 pm »
Martin
Are you surprised by that?  :-DD
« Reply #103 on: October 08, 2019, 09:13:44 pm »
Martin
I have a three-phase 16A 230/400V supply to the workshop. It is shared with the computers (including a 2KVA UPS with ~270 kilos of battery bank) and the machine workshop, where there are several 3-phase machines like drill press, air compressor, etc. I do not expect fuses blown, but sometimes the RCCB takes a dislike to the devices I connect...
Offline Martin.M
  • in Tek we trust
« Reply #104 on: October 09, 2019, 05:01:44 pm »
left side from the work table:
Tek 551 (850W)
Tek 555 (1000W)
Tek 555 (1000W) yes, it`s a pir of them
Tek 556 (850W)
Tek 565 (500W)
Tek 549 (600W)
Tek 533A (< 500W)
at the right side from the table ...
The following users thanked this post: Cubdriver, med6753
« Reply #105 on: October 10, 2019, 05:24:05 pm »
Tek 551 (850W)
Tek 555 (1000W)
Tek 556 (850W)
Tek 565 (500W)
Tek 549 (600W)
Tek 533A (< 500W)
Impressive.
L1: 533A+549+565 = 1600W
L2: 555+666 = 1850W
L3: 555+551 = 1850W
L1 is always loaded more than the others, so will get the lowest load. Still, all three phases come in under 10A, with headroom.
Oh, you don't have threephase "Drehstrom" in your workshop? I've lived in apartments with 3x16A main fuse. Sweden, home of ASEA (the A in ABB) and three-phase!
Offline Martin.M
  • in Tek we trust
« Reply #106 on: October 10, 2019, 06:03:02 pm »
not so easy to calculate that, it was the e left side of the table  :)
If you are interested I have some details at https://www.eevblog.com/forum/testgear/vintage-tek-restoration-pictures-by-martin/
greetings
Martin
The following users thanked this post: Larryc001
Offline Larryc001
« Reply #107 on: December 22, 2019, 10:42:47 pm »
Some of mine.
The following users thanked this post: xrunner, Cubdriver, med6753, 0culus
Offline 0culus
« Reply #108 on: December 22, 2019, 11:31:58 pm »
Daaaaang, dude. Hope you have strong floor joists.  :-DD
That's a super awesome collection. One day I hope to own one nice example of a Tek vacuum tube scope. Maybe.
Offline xrunner
  • hp>Agilent>Keysight>???
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #110 on: December 23, 2019, 12:08:51 am »
Schweet bunch of scopes there!!   :-+ :-+ :-+
-Pat
Offline Michael Lloyd
  • NE5U
    • Wild Light Imaging
« Reply #111 on: December 23, 2019, 12:43:24 am »
Some of mine.
Wow, are you Paul Carson's neighbor??
Offline Cubdriver
  • Nixie addict
« Reply #112 on: December 23, 2019, 01:29:58 am »
Some of mine.
Or did you visit Germany and clean out Martin's place?
The following users thanked this post: Michael Lloyd, mnementh, Larryc001
Offline VK5RC
« Reply #113 on: December 23, 2019, 02:23:35 am »
Lovely gear, I can imagine the sound and smell of them being used!
Rob
Offline Larryc001
« Reply #114 on: December 23, 2019, 04:15:13 am »
I am having trouble posting but hopefully I can figure it out and put up a few more pictures.
Offline David Hess
  • DavidH
« Reply #115 on: December 23, 2019, 04:16:10 am »
I have a pair of 500 series Tektronix oscilloscopes, a Tektronix 184 time-mark generator, and a pair of ESI 250DA impedance bridges.
Offline Larryc001
« Reply #116 on: December 23, 2019, 04:21:52 am »
A few more.
Offline Larryc001
« Reply #117 on: December 23, 2019, 04:29:48 am »
First transistor scope the 321 and 321A.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #118 on: December 23, 2019, 04:38:32 am »
 :-DMM   :P
The following users thanked this post: xrunner, med6753, Michael Lloyd, mnementh, Larryc001
Offline Larryc001
« Reply #119 on: December 28, 2019, 08:48:07 pm »
I should clarify my response and photos. Although all of my many scopes are fully working, I don’t really use them for troubleshooting. They are really a collection. As the topic was more like vacuum tube instruments being actually used, my posts were a bit off topic. I have a 2465A, a 2213, and a 2445 that I use to work on the big scopes. My apologies.
Offline 0culus
« Reply #120 on: December 28, 2019, 08:59:28 pm »
Absolutely nothing wrong with that. Thanks for sharing.  :-+
Offline BravoV
  • +++ ATH1
« Reply #121 on: December 28, 2019, 09:07:01 pm »
You're wrong, that 2465A, 2213 and 2445 still fall into "vacuum tubes" test equipment as for it's screen.  :-DD
Thanks for sharing the collection.  :clap:
Offline Larryc001
« Reply #122 on: December 31, 2019, 12:10:12 am »
Here is an interesting website from Julian Bunn, a long time electronics enthusiast and Caltech professional. He has a lot of stuff here including the Tektronix portion:
http://pcbunn.caltech.edu/jjb/Tektronix/tektronix.htm
His main site is at:
http://pcbunn.caltech.edu/default.htm
Many tubes here!
Offline David Hess
  • DavidH
« Reply #123 on: December 31, 2019, 02:56:17 am »
I excluded CRT oscilloscopes because EEVBlog does not allow posts that long.
Offline BravoV
  • +++ ATH1
« Reply #124 on: December 31, 2019, 03:14:56 am »
Well, in that case, you need a sanctuary for that kinda post, anytime, you're very welcome at TEA.  >:D  :-DD
