The 8566B arrived by local motor vehicle courier a few days ago. It was very well packaged in close cell foam over sized double wall boxes. The driver unpacked the units, and was kind enough to take the packing material back for recycling or re-use.
This is one clean 8566B. According to the serial numbers, the RF section was built 7th week of 1994, Display section 5th week of 1995 putting this system near the last years of production The CRT is sharp & bright with no burns or signs of abuse.. The RF section checks out good so far. I'll need to do a check and cal to verify its OK, but so far so good. Even the air filters are in very good shape with minimal mechanical lumps, bumps of scrapes. Last cal date was 2008. Previous owner was Loral Aerospace systems. It has the opt. 002 or "Turbo" speeded up processor and the demo program installed. hp Catalog price at that time (1994-95) was $78,350 USD
For the price of less than most "hobby" spectrum analyzers cost new including delivery, this was an absolute bargain.
Display using a signal from the sweeper about 5 GHz (delta market set for a quick check), as delivered no adjustments or cleaning done.
Feeling pretty luck and good about this 8566B.
Now, I'm going to retire the other spectrum analyzer.
Bernice
I bought an ex rental HP8566AB (A converted to B) about 4 years ago to give me a capability up to 22GHz as my other analysers only run to about 1800MHz.
It's a very special beast but mine hasn't been totally reliable. However, the faults have been easy to fix and I managed to get the CRT really sharp by servicing and adjusting the Z circuits. See example screen shot below. The image looks a bit dull and gloomy but it's the only way my camera can capture just how sharp the CRT now is
There are a few downsides in terms of performance though. I think the 8566B is the only high end lab analyser that we didn't ever buy or rent at work. Cost was one obvious reason but also the first mixer IP3 and 2HI are quite weak on it when used on range 1 up to 2.5GHz. The phase noise performance (at 1kHz to 200kHz offsets) is 'good' but not good enough for the work we were doing back in those days.
The HP8568B was better in these areas (up to its 1500MHz limit) and the 1980s built Advantest TR4172 outclassed them both in most of these areas. We upgraded to the TR4172 when the HP8568B couldn't quite deliver the SFDR or phase noise performance we needed back then. The TR4172 was insanely expensive in the late 1980s because of the strong japanese yen and we were again donated one by our customer (which was nice) as we couldn't afford to buy one ourselves. There were various rumours it cost £60k with its numerous options fitted.
The internal build quality of the TR4172 is very impressive. At least as good as anything from HP from the same era.
