Author Topic: Do you recognize this connector? Chauvin Arnaux E14 Current probe  (Read 1991 times)
Offline diegoperezTopic starter
After searching for a while, I could not find any information about this current probe.
It is very similar to the ubiquitous chauvin arnoux E3N current probe, which I think is rebadged under various other brand names.
But this one does not have the dc-offset trim pot nor the over-range led indicator. In addition, I think this current probe needs a terminating resistor at the connector end, because the gain seems to be wrong when connected to a 1-MOhm scope input impedance.
Any info regarding the connector or the probe will be welcomed.
Thanks,
Diego
Offline 0xfede
Re: Do you recognize this connector? Chauvin Arnaux E14 Current probe
« Reply #1 on: February 24, 2018, 09:09:19 pm »
Hi Diego,
it seems to me a lemo connector.
Have a look to their site:
https://www.lemo.com/en
Best,
0xfede
Semel in anno licet insanire.
The following users thanked this post: diegoperez
Offline vtp
« Reply #2 on: February 25, 2018, 09:41:10 am »
Try Hypertronics D-series, possibly D02.
The following users thanked this post: diegoperez, shakalnokturn
« Reply #3 on: February 25, 2018, 10:44:33 am »
Wow, that's right. It's a D01 series with 3 contacts (but only two are populated).
After comparing the dimensions whith the catalogue, I also noticed a 'D01' engraving mark in the connector  :-[ , which further confirms it.
Thank you!  :)
Offline angeeinstein
  • Country: at
« Reply #4 on: January 16, 2024, 07:39:43 pm »
Did you get this probe to work?
Offline shakalnokturn
« Reply #5 on: January 18, 2024, 10:46:18 pm »
This also seems to be the same connector I was inquiring about in this topic:
https://www.eevblog.com/forum/testgear/dossena-multiver-3-sn-3-phase-network-analyser/msg5096883
