To avoid multiple edits on the same post, I'll continue here.
I finally got around to hooking up serial coms, below is the output from boot.
As suspected there is a CRC-Error early in the boot process, it is the
BL_IMAGE_TYPE_BIN image that is corrupt.
Time to read more before anything gets more complicated.
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: fsmc-ecc1 128 MiB
In: serial
Out: serial
Err: serial
SerNum:serial number not programmed
Chip: BD Board Rev: 4
Net: smsc
Press space to stop autoboot: 0
## Booting kernel from Legacy Image at f8050000 ...
Image Name: PBOOT
Created: 2011-08-24 22:35:34 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 36045 Bytes = 35.2 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Aug 24 2011 15:15:48
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXXOOOOXXOOOOOOOOXOXOXOOOOOOOXOOXOOXOOOXXOOOOOOOOOOXOOOXOXXOOXXXOOOXOXXXXXOOXOXXOOOOOXOOXXXXOXXOOOXOOXXOXXOXOOOXOOXOOXXOOOXOOOOXOXOOOOOXOOOXOOXOXXXOXOXOXOXXOXXXXXXXOOOOXOOOXOXOOOOXOOOOXXOXOOOOOOOERROR: Checksum failure (expected=0x270992F computed=0x2705DB2)
****** Checksum failure on record 77, ABORT!!! ******
Completed file(s):
[0]: Address=0x80361000 Length=0x130656C Name="" Target=RAM
Loading image 1 failed, trying next one
Loading image 2 from memory at 0xD1600000
BL_IMAGE_TYPE_UNKNOWN
Loading image 2 failed, trying next one
All images failed
Press r to reset
