Author Topic: Upgraded SDG1000X Plus AWG's  (Read 7297 times)
Offline newbrain
Re: Upgraded SDG1000X Plus AWG's coming
« Reply #50 on: August 15, 2024, 08:23:42 am »
Tautech said that will be reserved for China market so you need to buy from grey market.
Better go with the 2000X which is the best AWG on the market for his price.
I think tautech was specifically referring to the 25 MHz model (highlighted in the quote), but up to him to clarify (thanks!), ISTR the same applies for the regular 1032X.
On the other point, it all depends on the price, but I generally agree.
Offline hpw
« Reply #51 on: August 15, 2024, 01:21:25 pm »
I do not know why only up to view 35MHz, as Audio ADC/DAC requires up to 100MHz square waves clocks and on the other channel a very low THD audio signals.
Supporting wide digital squares levels as predefined is a nice to have otherwise at first to trimm
Offline tautechTopic starter
« Reply #52 on: November 12, 2024, 03:33:15 am »
Western release of 3x SDG1000X Plus models, 25, 30 and 60 MHz.
OP updated.
Datasheet
https://int.siglent.com/u_file/download/24_11_11/SDG1000X%20Plus_DataSheet_EN01A.pdf
Offline markus_jlrb
« Reply #53 on: November 12, 2024, 03:24:31 pm »
>to clarify, SDG1025X Plus will be a China only model so OP updated.
Played with this device at Electronica2024 in Munich today.
The SDG10xxX Plus will be soled in Europa too. 16Bit DAC.
Price located a bit above 300$ for the starter model (25MHz).
Markus
The following users thanked this post: artik
Offline Ulrich.G
« Reply #54 on: November 13, 2024, 12:38:20 pm »
Batronix has the 30Mhz & 60Mhz models already in stock
https://www.batronix.com/versand/siglent/SDG1000XPlus.html
Offline blackdog
  • Please stop pushing bullshit...
« Reply #55 on: November 13, 2024, 06:10:10 pm »
Hi Tautech,  ;)
If you already have the Plus version of the 1000 series, can you do this test set-up?
Here I used the SDG 1032X, at 1MHz and a signal level of 999-mV and 1.1V-PP.
A short good 50-Ohm coax cable and a good 50-Ohm BNC in line terminator.
Then I show two pictures here below, one is at 999mV TT in 50-Ohm and the other is at 1.1V in 50-Ohm.
This shows the differences in the output amps.
The rise and fall times are around 3.5nSec.
I would like to see this measurement repeated on the Plus models, please.
In both measurements, I use alternating triggering so that both flanks come into view at the same time.
This is the 1MHz signal of 999mV (just before switching output)
The scope is SDS HD 12 Bit, with 500Mhz bandwidth.
First the 999mV picture almost no abberations verry good!
And this is ad 1.1V-PP Output Level, not bad but good be a little better.
So I am interested in the quality of pulse abberations.
If it is good enough from the new model I will purchase such a generator for my second workbench and then I can also use it for Bode Plost with the Siglent scope I already have there.
In any case, thank you very much!
Bram
« Last Edit: November 13, 2024, 08:34:12 pm by blackdog »
Necessity is not an established fact, but an interpretation.
« Reply #56 on: November 13, 2024, 07:59:47 pm »
Hi Tautech,  ;)
Bram
Won't have any until next order....next year ETA.
3.5ns not possible with 1kX Plus.
Offline blackdog
« Reply #57 on: November 13, 2024, 08:42:25 pm »
Hi tautech,  ;)
If the flank steepness are really 10nsec from the Plus model, then I see no reason to buy a Plus model from the 1000 series... and 446,49 Euro's!
The only reason stopping me from buying another SDG1032X, is the stupendous operation of the encoder of this series of generators, but enough has already been said about that.
Thank you for the reply!
Kind regards,
Bram
« Reply #58 on: December 12, 2024, 08:07:52 pm »
Offline RBBVNL9
« Reply #59 on: December 25, 2024, 06:25:41 pm »
PRBS code types up to 40 Mbps
PRBS3 ~ PRBS32 code output, with adjustable rate between 10-6 bps
There are not many affordable (new) instruments on the market that can generate PRBS signals. Having built my own PRBS generator last year, I am excited to see this function now being added to this popular series of devices. But the "adjustable rate between 10-6 bps" in this quote kept me puzzled.
I now think where this comes from. According to the datasheet, the rate can be set "between 10-6 bps and 40 Mbps". That first scientific notation somehow must got degenerated into the text in the quote above  ^-^ ^-^
I guess this 10-6 bps setting is included for people with a lot of patience. If I'm not mistaken, that is one bit every million seconds, so 11.6 days per bit. To play back a single, regular PRBS PN15 sequence (which has a length of 215-1 bits) would take 1040 years, not to mention that you at least need a couple of these sequences in order to do things such as locating bit errors....
« Reply #60 on: December 25, 2024, 07:25:41 pm »
:-DD
Back when I copy/pasted from Gurgle Translate little things might go wrong.....
Now we have an English datasheet which does indeed state 40 Mbps.
