Author Topic: Does anyone have a copy of his Rigol Bildschirmkopie software?  (Read 9051 times)
Offline rwetferTopic starter
  • Country: cn
http://peter.dreisiebner.at/rigol-bildschirmkopie-lan/
the link is Error occurred: 404 - not found now.
would anyone give me a copy of "rigol-bildschirmkopie-lan"?
you can email me rwetfer@qq.com.
I will be deeply grateful
  • Country: cn
Re: Does anyone have a copy of his Rigol Bildschirmkopie software?
« Reply #1 on: August 12, 2018, 10:14:51 am »
 :clap: ;D thank you very much
Offline tooki
« Reply #2 on: August 12, 2018, 01:35:56 pm »
Why is it not available any more, PeDre?
Offline 2N3055
  • Country: hr
« Reply #3 on: August 12, 2018, 02:21:22 pm »
It is available...  :-//
Dr. Richard W. Hamming
Offline Mark
« Reply #4 on: August 13, 2018, 01:35:10 pm »
A massive thank you to Peter for his software (you provided a link a few years ago but I didn't use the software at the time).
Only recently I've been running thousands of tests and needing to capture waveforms for every event, Peter's software makes copying 1000 waveform images very easy!
The USB connection is faster than ethernet once you get the drivers installed, but it's too fast for my DS1054s to keep up so I normally use 1second interval.  The DS1054 capture counter sometimes doesn't increment if the "fast as possible" setting is used.
Very useful software, thanks again!  :D
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #5 on: August 14, 2018, 08:12:06 am »
*cough*
I have mentioned this very thing to the author. It would be super helpful to have some values between 1 capture per second and, say, 4 captures per second (perhaps not in integer values).
The issue is, as you've stated, that the scope's UI can't keep up at "as fast as possible" so you end up taking screenshots of incorrect data. If it were 3 captures per second or even 2, it would be able to keep up and still get a nice frame rate.
Offline technogeeky
« Reply #6 on: August 30, 2018, 01:31:31 am »
I am working on a new extended version of the screen capture tool. The curve/trace data should also be transferred and displayed. At the moment only USB-TMC devices are supported with installed WinUSB drivers. There will only be one Windows version, but 32 and 64 bit.
There will be configuration files for the different devices. I'm not sure how all this will work yet.
Peter
Peter:
Thank you again for your work making this software. It's by far the best for making GIFs like this which I think are sometimes the best way to convey information. Like this, the rise in noise level over a 1 hour period of a DC-DC converter as the battery input drains:
FYI, I make these using your software and then some basic built-in features in GIMP.
The reason this one looks so smooth is because it's a long time average. But on my machine, with my scope, if I select fastest then it will grab something like 3.3 frames per second but it will limit the Measure display, the FFT (if selected), the math (if selected) etc. The display just doesn't update correctly. But I suspect if I could choose 3fps or 2fps instead, I would get this information updated and have nicer smooth updates.
I use the old software on Linux through wine (32-bit wine "chroot" configuration). It works great. Both LAN and USB work. There are no bugs. USB is much faster. I would be happy to formalize the steps needed to make it work so that you could display the instructions and claim support for Linux (if you even care to).
Do you ever plan to open source on these tools?
« Last Edit: August 30, 2018, 01:36:15 am by technogeeky »
Offline technogeeky
« Reply #7 on: August 30, 2018, 07:23:18 am »
Hi technogeeky,
The source code for the Bildschirmkopie-program is on my website. The program was programmed with Xojo.
Now I use PureBasic and the source code is also available later.
I could support animated GIFs, PureBasic has functions for that.
I have to look at the problem with the 3.3 frames per second. But my computer isn't that fast.
Peter
The key feature would be the ability for the user to enter a float/double as the number of captures per second. I think the program is really organized by seconds per capture, so you would need to enter a something like 0.3, or 0.333, or 0.5. Or even 0.25 (if it can indeed go that fast, and not drop text).
That would be superb.
Offline technogeeky
« Reply #8 on: September 07, 2018, 04:31:02 am »
It looks like you deleted the post talking about the new version.
I downloaded it and used it -- it works great! I wanted to show you an example of the type of recording this feature enables.
Here I have:
* 1 MHz sine wave
* FFT enabled (memory)
* sweep voltage downward over about 10 seconds
* as fast as possible
There are about 5 updates of the FFT in the "as fast as possible" mode, because the scope is so busy sending screenshots that it doesn't bother to update the FFT. The same thing can be seen (to a lesser extent) with measurements.
* every 600ms
But with a carefully selected update time, we see basically the same thing we see on the scope screen (or every other screen update is screen captured).
And since you've helpfully allowed us to set the value ourselves, we can just determine by experimentation if the update is going to be fast enough to capture what we want or not, and adjust the timer.
Thanks very much!
« Last Edit: September 07, 2018, 04:35:18 am by technogeeky »
The following users thanked this post: PeDre
Offline Fungus
« Reply #9 on: September 07, 2018, 12:10:13 pm »
What's the fastest update rate people are getting with this program?
I only ask because I just tried it on my machine and I was like, damn, that's slow.
« Last Edit: September 07, 2018, 12:22:50 pm by Fungus »
Offline Fungus
« Reply #10 on: September 08, 2018, 08:37:42 am »
Windows 7 (64-Bit) CPU Celeron J1900
LAN:
DS1000Z - 4 sec.
USB:
DS1000Z -  0.5 sec.
Really that much difference between USB and LAN?
Maybe the problem is in the LAN library being used. One of the reasons I asked is because I did a quick test two days ago and I could download a screen over LAN in about 800ms. With this program it took about 5s between updates, which seemed very slow to me.
(also on Windows 7)
« Last Edit: September 08, 2018, 08:45:38 am by Fungus »
Offline Fungus
« Reply #11 on: September 08, 2018, 10:19:49 am »
I have programmed the RPC/VXI protocol myself. I have no comparison to other programs that also use this protocol. With a Telnet connection it is surely faster.
Ah, OK.
When it detected my DS1054Z is said it was on port 618, not port 5555. I wondered about that.  :-DD
So... the DS1054Z has two different remote-programming interfaces.  :o
Offline BravoV
  • +++ ATH1
« Reply #12 on: September 27, 2018, 06:23:13 pm »
I will not change anything in the program Rigol-Bildschirmkopie except for possible errors.
I am working on a new program Messinstrumente. Here is the translated help page, maybe someone can use it:
http://peter.dreisiebner.at/messinstrumente/help.htm
It is in alpha state because many functions I imagine are still missing. But all existing functions can be used.
Peter
Great tool, thanks.  :-+
Just a suggestion, make a new special thread for it please, as this thread will sink into the abyss.
Offline ober
« Reply #13 on: October 14, 2018, 04:40:21 pm »
Hi PeDre,
could you compile Rigol-Bildschirmkopie for macOS 64 bit?  macOS is stopping the support for 32-bit apps, and it would be nice to keep it running until Messinstrumente is ready for prime time.
Offline Andrey_Ak
  • Country: kz
« Reply #14 on: April 18, 2023, 06:12:21 am »
you can email me admin@tis.kz
Offline Mark
« Reply #15 on: April 18, 2023, 09:39:24 am »
I sent you a PM.
The following users thanked this post: Andrey_Ak
Offline MegaVolt
  • Country: by
« Reply #16 on: May 02, 2023, 03:26:17 pm »
Does this work with the new MSO5000?
Offline Vicne
« Reply #17 on: February 02, 2024, 11:13:08 pm »
FWIW, a copy of this software can still be found currently on this page: https://www.rsbasic.de/backups
The filename starts with "2017-02-09_RigolBildschirmkopie" and depends on your OS.
While the author's website is down, a copy has been archived at https://web.archive.org/web/20170720140733/http://peter.dreisiebner.at/rigol-bildschirmkopie-lan/ , with useful home, download and help pages.
Hope it helps,
Vicne
The following users thanked this post: egonotto, coromonadalix
