Author Topic: Does anyone have artwork for the Tek 465/465B Vertical Atten Knob Skirts?  (Read 622 times)
Online scopemanTopic starter
Does anyone have artwork for the Tek 465/46B Vertical Attenuator Knob skirts? Or better yet has replacement knob skirts for sale? At one time they were on eBay but
they aren't there any longer.
I have 4 scopes that are otherwise mint that have bad skirts, either broken or lettering rubbed off.
Sam
W3OHM
W3OHM
Offline tggzzz
Re: Does anyone have artwork for the Tek 465/465B Vertical Atten Knob Skirts?
« Reply #1 on: September 12, 2024, 11:54:20 pm »
I have a 475 skirt. I suspect if you delete the "100" then it will work.
Unfortunately the forum won't allow .odg files (for you to edit) as attachments. Oh well.
Offline Kim Christensen
« Reply #2 on: September 13, 2024, 12:43:30 am »
Can't you just ZIP the .odg file and attach that?
Offline tautech
« Reply #3 on: September 13, 2024, 12:49:14 am »
Yup, you'd expect a member with 20k posts to know how to work around forum filetype limitations. Oh well.
Just adding a .txt and uploading it here with a note to remove the txt extension has worked here forever.....
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: September 13, 2024, 12:50:17 am »
Yea - As far as I know you can do any file like that. I know I've gotten around it with other file types like that.
Offline tggzzz
« Reply #5 on: September 13, 2024, 09:28:59 am »
I haven't tried to upload any executable files to this forum before. The zipfile and similar techniques have failed in the past, so I didn't repeat the attempts here.
I'm not going to apologise for not knowing the different workarounds on each and every website/forum that I use.
Anyway, save the attachment, remove the .txt suffix, and hope it is is useful.
« Reply #6 on: September 17, 2024, 12:52:39 am »
Thanks to all. I think I figured out on my own how to create the artwork.
Sam
W3OHM
