Author Topic: How to ignore initial power on spike in single mode (Rigol)  (Read 1000 times)
Offline loki42Topic starter
« on: April 14, 2019, 02:13:52 pm »
I'm attempting to use my Rigol DS1054Z oscilloscope to work out why my MIPI DSI connection isn't working. Obviously a challenge is the high clock speed but I'm keen to check the lower clock stuff like TE and the reset line and this all changes on start up. How should I set the scope to single trigger mode but ignore the first spike from powering on? Is setting up a pulse trigger the right way? Is there a discussion anywhere on what to use the different trigger modes for?
Offline Fungus
Re: How to ignore initial power on spike in single mode (Rigol)
« Reply #1 on: April 14, 2019, 07:48:00 pm »
There's a fine manual...  :popcorn:
