Author Topic: Does the diode mode of the multimeter vs Curve tracer  (Read 433 times)
Offline Orxan1989Topic starter
  • Country: az
« on: November 07, 2024, 05:51:01 pm »
Does the diode mode of the multimeter (with the red probe on the ground) replace the curve tracer in integrated circuit testing? If not, why?
Offline coromonadalix
Re: Does the diode mode of the multimeter vs Curve tracer
« Reply #1 on: November 07, 2024, 06:07:20 pm »
not
a curve tracer use a scope,  that way you see the dut  specs and how it behave, and  if it leak ...   a meter will not show it like this,  on some   it help you test a zenner too
a meter will test in voltage, mostly up to 3v,  or some eevblog ones or some others who can output 15 vdc,   you get the junction voltage of a diode  0.3v
0.6v  etc ..   can test some zenners,  but there is a limit
a meter in ohms   you may see if you are in forward or reverse   if you see conduction
as tools:  get both of them, learn on how to interpret read values,  tests them,  interference of parts in parallel on / in the circuit   etc ...
you have 2 questions here about curve tracer,  pls avoid multiples thread ....  i know it is not identical,   but be careful ...
« Last Edit: November 07, 2024, 06:11:19 pm by coromonadalix »
The following users thanked this post: IC_Toaster
Online Fungus
« Reply #2 on: November 08, 2024, 07:33:31 am »
No.
Because it doesn't show a curve on a screen.
