Siglent has recently come out with the SDS1000X Series which is a replacement for the old SDS1000CxL. As their predecessors the SDS1000X are 2ch scopes, plus they are pretty new so there's little experience as to bugs and issues. Plus the prices are close to what Rigol asks for it's 4ch DS1054z so it's really a no-brainer.
I have owned both.
After short use for one work what need _cheap_ 4 channel oscilloscope I made conclusion that I do not want anymore use this DS1000Z for any purpose.
Also it was case where do not daily adjust scope for different tests. Sorry but I do like these shared vertical adjustments for all channels.
SDS1000X have some advantages over DS1000Z.
-Bigger display (8" vs 7")
-separate vertical adjustments
-internal 50 ohm input impedance or is is better say resistance. Rigol -
-lot of less signal noise
-always switchable Sinc on/off (and also not this Sinc joke what Rigol have. Explanation in other thread)
-always bacround running history, up to 80000 previous waveforms. Rigol -
-max 60000wfm/s in normal mode. Rigol much less
-256 level intensity grading and far better than in DS1000Z
-color grading, Rigol -
-max 60000wfm/s mask test and speed independent of result, Rigol much slower and also speed depends result what leaads to extremely low speed
-max 500000 segment/s speed in Sequence mode with timestamps. Rigol - (or some kind of slow frame recorder)
-true analog 500uV/div full bandwidht sensitivity. Rigol - (Rigol 1mV/div is pixel zoomed fake sensitivity and perhaps also 2mV/div in is not true analog sensitivity.)
-much better trigger accuracy (perhaps least partially due to Rigol noisy input?)
-when I owned Rigol I also used it small time to common purposes "looking around" and there was lot of situations where scope crash and only solution was shut off and start agen what also was frustrating due to long boot time.
About Rigol Sinc and vertical sensitivityexamples about Rigol noise. All as perfect face to face and both just fresh selfcal.
It need also note that this is 200MHz model. 100MHz model have aaround 3dB less noise (due to bandwidth) and this is also confifrmed by tests).
No need comment.
Then if just look Siglent SDS1000X and Owon XDS3000A
(but here need also note that Owon is 100MHz model and Siglent is 200MHz model)
Single shots.
Not bad.
In this case my opinion is that Owon beats Siglent clearly (also Zoom is better because Owon have vertically higher zoom window. And Owon have full vertical range display where Rigol and Siglent only 80% from full scale) And lot of better TFT what Rigol or Siglent. Better contrast and brightness and wiev angle.
