Author Topic: Schematics of photos of SLA1016 wanted - logic analyzer for Siglent scope  (Read 2404 times)
Offline wsowa
Has anyone tried to reverse engineer Siglent's MSO addition to SDS1104X-E scope - SLA1016? I imagine it can't be very complicated device. Perhaps someone has schematics or maybe an owner of the device would like to take it apart and post the pictures?
Offline tmbinc
Unfortunately I still haven't seen a teardown of it, but common belief is that there's an independent acquisition system in there (so basically Zynq FPGA+Memory) that syncs with the scope, and (slowly) transfers the capture to the scope.
Offline wsowa
Oh, ok, I see. So it won't be that easy and low cost to replicate. These FPGAs are rather quite expensive...
Offline Gege34
I have it (at works) but the case is sealed. So impossible to open without damaging it.
But like tmbinc said I suppose it's base on FPGA and not so easy to duplicate.
Offline GerryR
ITT Pomona made a logic probe kit to interface with an analog scope, mdl MX 9100.  It had 8 inputs, but you could cascade up to 3 units for 24 points to monitor.  Operating frequency was DC to 20 MHz.  It had trigger word capability and other trigger options.  It had 3 memory banks with 16-word memory depth each for replay; not much but worked pretty well.  I don't know how it would work with a DSO, but I expect it would be ok.  If you can hunt one down, it might be an inexpensive option for you.  Just a thought.
Still learning; good judgment comes from experience, which comes from bad judgment!!
Offline tv84
  • Country: pt
The SLA1016 surely has a Zynq inside.
I conclude that from this.
The app of the SDS1004X-E can be run in the Zynq of the SLA and work accordingly to its specificities.
