Author Topic: TEKTRONIX TDS 350 - option 14 board / or from compatible model.  (Read 753 times)
Offline alitronixTopic starter
« on: October 11, 2022, 09:53:33 pm »
Hi, I'm looking for a "module" option 14 (to buy) for my tek tds 350.
All I want is the VGA output , for some reasons that is what I want to use from the module.
If someone have to sell/donate I'm interested.
I'm looking also for a 350 defective one to buy, from were I want to pull it out the option.
Any suggestion or info/link is good for me.
Thank you,
Alin
this is for Europe.
I Have Done So Much with So Little for So Long, that Now I Can Do Anything with Nothing Forever.
Re: TEKTRONIX TDS 350 - option 14 board / or from compatible model.
« Reply #1 on: October 15, 2022, 04:45:15 pm »
ok... what I miss? I asked in wrong place?
any information about the subject in good for me.
Thank you.
Offline james_s
« Reply #2 on: October 15, 2022, 06:03:20 pm »
It's fine to ask here, the likely answer is that nobody has one of these available, they were relatively rare in my experience.
Fortunately for a TDS300 series you don't need a module, the VGA signal is available from a header on the main PCB so all you need is a VGA connector, a PC slot bracket from a video card and a ribbon cable to assemble your own.
« Reply #3 on: October 22, 2022, 04:40:13 pm »
yes , I confirm it,  is not very clear if you look at the service manual,
but after a close look at the board and in service manual and also hooked up an another oscilloscope on the connector I figure it out how to connect the VGA DB connector.
I put some pics below maybe someone it interested in, there is also the pin-out configuration of the connector.
Offline james_s
« Reply #4 on: October 22, 2022, 05:43:49 pm »
I think it's deliberate that it's not very clear, Tek wanted to sell the expensive option, they didn't want people just hacking in a connector.
Looks like a nice clean job.
