Hey everyone,
My next project is a DIY valve amplifier kit, so having something which can handle decent voltages and currents without killing me is an absolute imperative. I upgraded my very, very old Fluke 77 for a used Fluke 175 off trademe, and it seems in pretty good condition.
The first thing I checked after it turned on was the fuses. They both appear not to have blown, but it looks like the previous owner had a wildly-out-of-spec fuse in the 440mA spot, and I wanted to make sure that:
a) I was reading it correctly; and
b) there isn't anything fishy about the 11A fuse too
I've already ordered a proper replacement 440mA from element14, but given the intended use of this meter is the high energy inside valve amps, I want to be 100% that I'm as safe as I can be before touching anything. I'm a newbie to electronics, but am slowly learning and taking on projects to learn as the hobby deepens. That being said, I have an immense amount to learn, so coming here with my question was intended to check with infinitely more experienced and knowledgeable folks to make sure my thinking is correct.
Cheers!
