Products => Test Equipment => Topic started by: Kappes Buur on July 24, 2016, 02:57:21 am
This may be of interest to some, I had not seen this mentioned before
DS1000Z_Plus"_now_field_upgradable_to_MSO (https://www.rigolna.com/news-and-events/2016/New_"DS1000Z_Plus"_now_field_upgradable_to_MSO_at_any_time/)
This has been discussed here before:
https://www.eevblog.com/forum/testgear/new-rigol-ds1000z-plus-models-ds-models-which-are-mso-field-upgradable/
(https://www.eevblog.com/forum/testgear/new-rigol-ds1000z-plus-models-ds-models-which-are-mso-field-upgradable/)
If I recall correctly, these are not as easily hackable as the regular DS1000Z scopes, but the more complex procedure for the MSO1000Z series applies: https://www.eevblog.com/forum/testgear/you-can't-unlock-a-mso1000z-series-scope-without-a-memory-dump-and-other-lessons/ (https://www.eevblog.com/forum/testgear/you-can't-unlock-a-mso1000z-series-scope-without-a-memory-dump-and-other-lessons/)
