Hi All,
I have a Rigol DS1052E its 12 months old and has had only light use.
Last time I used it I was plying around with the triggering now however it seems its somewhat stuck in the trigger menu as the inputs do not seem to function correctly.
Power off/on does not help.
I turn it on and press AUTO with channel 1 connected to the test signal, it captures the test signal fine.
But when I turn the vertical scale knob (V/div) nothing happens, turning the horizontal scale knob (time/div) it moves the trigger point ie to left or right of center, but not (time/div)
I can not adjust the (V/div) or (time/div).
Am I stuck in the trigger menu? Is there setting/menu option I need to exit out of?
Any ideas how to fix this, I'm hopeing its a case of user error and that's its not busted
I have tried self Calibrate and also Storage - Factory - Load.
