Poll
Can you reproduce this bug?
Firmware ver. 4.02 - can reproduce
17 (27.4%)
Firmware ver. 4.02 - can't reproduce
0 (0%)
Firmware ver. 4.03 - can reproduce
8 (12.9%)
Firmware ver. 4.03 - can't reproduce
1 (1.6%)
I don't own a DS1054z, I just want to look at the results. :D
36 (58.1%)
Total Members Voted: 58
Author Topic: DS1054z bug (with poll)  (Read 7020 times)
Offline Anand
« on: May 21, 2015, 09:36:26 pm »
Input signal: probe compensation 1kHz square wave from the scope
Trigger: DC / CH1 / 1.5V
Aquisition: High Res / 120k mem. depth
Horizontal position: 0ps
Horizontal scale: 50us/div
I get the attached pic.
Firmware version: 4.03 and the bug was present on 4.02.SP4
« Last Edit: May 21, 2015, 09:40:09 pm by Anand »
trashf.
Offline kwass
Re: DS1054z bug (with poll)
« Reply #1 on: May 21, 2015, 10:16:54 pm »
Good find, but weird how it has to be exactly those setting on the Aquire menu to see this.  IIRC people of this forum found that High Res mode was useless, so this is yet another reason to never use it.  I've added this to the bug list thread.
-katie
Offline Anand
« Reply #2 on: May 21, 2015, 10:23:43 pm »
Well, I've got another bug, that dissapears when High Res is on. I'll post that soon, too.
Sweet, thanks, I've wanted to do it myself but I didn't know if it was just me experiencing this bug so... I asked around first. :D
« Last Edit: May 21, 2015, 10:30:58 pm by Anand »
trashf.
Offline DanielS
« Reply #3 on: May 22, 2015, 01:22:33 am »
That's a strangely specific bug.
And yes, I got that on my 1054Z too.
This is a strangely specific bug. It works on any channel when the same channel is used as the trigger source and only one channel is enabled at a time.
I probably would never have come across this bug on my own since I practically always use at least two channels and usually limit memory depth to 30-60k points when I save waveforms.
Offline miguelvp
« Reply #4 on: May 22, 2015, 01:48:33 am »
Too bad the poll doesn't have a I don't own a DS1054z so we can look at the results.
Offline alsetalokin4017
« Reply #5 on: May 22, 2015, 02:49:47 am »
Yep,  mine does that too. (firmware 04.02.SP4)
I wonder if "unhacked" scopes do it.
Offline evb149
« Reply #6 on: May 22, 2015, 02:54:53 am »
So the bug is that it shows the trigger point as preceding the displayed edge by a couple of hundred microseconds?
Offline kedwards22
« Reply #7 on: May 22, 2015, 06:10:06 am »
I've got a brand new un-hacked scope (still using the trial time) and it has the bug.
Offline Anand
« Reply #8 on: May 22, 2015, 07:22:38 am »
Fixed. :D
trashf.
Offline dom0
« Reply #9 on: May 22, 2015, 09:34:13 am »
Yep
« Reply #10 on: May 22, 2015, 03:55:30 pm »
Seventy-five microseconds, actually,  IF your horizontal trigger position is on the center graticule marker. Less if the trigger position is to the left, more if it is to the right of center. Seems weird that the error should depend on the screen Horizontal Position that way.
And it does it on Trailing Edge and Both Edges trigger slope settings as well.
« Last Edit: May 22, 2015, 04:04:29 pm by alsetalokin4017 »
« Reply #11 on: May 22, 2015, 04:12:52 pm »
In Horizontal Zoom mode it's even stranger.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #12 on: May 26, 2015, 06:12:32 pm »
Confirmed in DS1104Z-S. Only in High-Res mode though.
Could it be because 125MSa/s / 120 kpts = 1.04166666......?
« Last Edit: May 26, 2015, 06:32:30 pm by Jeroen3 »
Offline rolycat
« Reply #13 on: June 01, 2015, 09:43:51 am »
Fixed. :D
Why not just click the "View Results" button below the poll?
Offline Psi
« Reply #14 on: June 01, 2015, 10:26:33 am »
Its so specific that it could be a debug test that someone forgot to wrap with #ifdef debug
Offline jadew
« Reply #15 on: June 01, 2015, 12:08:39 pm »
I get this on the DS1104Z.
« Reply #16 on: June 01, 2015, 02:02:58 pm »
Has anyone who is running the latest 1000 series firmware version 04.03 tried this test to see if the bug is still there?
Online ebastler
« Reply #17 on: June 01, 2015, 04:42:35 pm »
Well, according to the poll above, 3 people have tried it and have all reproduced the error.
« Reply #18 on: June 01, 2015, 04:49:50 pm »
Duh... insert embarrassed smiley here ... Thanks....
Does anyone know what the 04.03 firmware actually _does_ fix (or change) then?
Offline ankerwolf
  • Country: at
« Reply #19 on: September 23, 2015, 09:08:03 am »
Hello,
it is a very special bug!
I can reproduce also in Version 00.04.03.SP1
BUT
ONLY at 120kpts & H=50┬Ás
AND depends on the position of T !!!
See attached pictures.
Offline Karel
« Reply #20 on: September 23, 2015, 06:51:19 pm »
Yep, same here with latest firmware.
But only when one channel is switched on. When switching on multiple channels, the phenomena disappears.
Offline ankerwolf
  • Country: at
« Reply #21 on: September 23, 2015, 07:17:45 pm »
That is right, because of the Mem.Depth is NOT 120k !
(And the bug ist only at 120k pts)
