Author Topic: Universal-Pegelmessgerät UPM550  (Read 1228 times)
Offline Charlie86Topic starter
  • Country: io
« on: December 10, 2017, 12:10:15 am »
For what kind of measurements was used this device? Does is still useful in this days (I am guessing it is pretty old)?
https://www.radiomuseum.org/r/sennheiser_universal_pegelmessgerae.html
Offline SparkyFX
Re: Universal-Pegelmessgerät UPM550
« Reply #1 on: December 10, 2017, 04:47:03 pm »
Well, the text says it´s a level meter 10Hz-1MHz, 30µV-300V AC input, 1kHz calibration source included. Probably used to test audio amplifiers for gain-bandwith.
A spectrum analyser or most modern oscilloscopes with an FFT mode will show a signal in that range with a wider bandwidth, concurrently with the other ranges.
Support your local planet.
  • Country: io
« Reply #2 on: December 27, 2017, 09:07:47 am »
Thank you for yours answer.
