On latest firmware 00.04.04.SP3 the X-Y mode at scale of 1ms makes the screen refresh about twice per second.
Older firmware worked better in that mode, after seeing youtube videos of others using DS1054Z with X-Y mode with scale at 1ms at descend speed. I think latest update added the fullscreen mode..
The device is not allowing downgrade.
I am fully aware that I can take a previous firmware release, open a hex editor and carefully increment the end of the version by a single digit at the top header, making the scope believe it is truly getting an upgrade.. But I feel like that's playing with fire (even with doing factory reset beforehand), and would break warranty.
I'd like to hear what you guys think! Should I refund and find another scope? Or should I really attempt force downgrade with higher firmware version at the header?
I don't think there's a unbrick tutorial for this scope
