Author Topic: DS1054Z hack still good?  (Read 32120 times)
Offline ebastler
Re: DS1054Z hack still good?
« Reply #50 on: January 05, 2018, 06:47:09 pm »
Yes.  :=\
Don't buy a "plus" model or an MSO though, those are much more difficult to "upgrade".
Online frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #51 on: January 05, 2018, 06:51:38 pm »
It has been and for ever will be a "hackable" scope since the flaw is in the implementation of the encryption - if Rigol wanted to fix that in firmware, they would have to also supply everyone who bought additional features at any point in time with new keys and I do not think they are willing to go through all this trouble.
Personally I would not want to be responsible for all the backlash this would cause.
He’s like a trained ape. Without the training.
Offline Fungus
« Reply #52 on: January 05, 2018, 08:53:03 pm »
Just about to purchase the scope
Can anyone help me and confirm that the hack is still working ?
Yes.
The day it stops working you'll feel a huge disturbance in the force.
Offline ibendwires
« Reply #53 on: February 01, 2018, 11:55:19 pm »
(Adding another confirmation based on a recent purchase)
Just received my scope today  ;)  and was able to apply the hack with no problems. However, I used the wrong option (DSFR) instead of the (DSER). So I had to go through the process of removing all of the features via the SPI commands and reapplying with the correct information  |O
Anywho. Of note, my unit was up to date from the factory with the most recent firmware version 00.04.04 SP3 which meant I didn't have to upgrade at all. And from what I can tell thus far, this is an excellent scope for the price point. As I was currently using a Tektronix TDS1002B.
FWIW, The threads in these forums sold me on the unit  :-+
Offline Topher_duino
« Reply #54 on: March 07, 2018, 03:11:05 am »
I got my scope in today.  Also with the 00.04.04 SP3 software.
I almost cried when the first 3 attempts failed
Then I realised that I err'd on one of the serial numbers when reading it off the screen. doh! :palm:
After looking at the rear end of the scope, I was right as rain.
Good luck all.
Offline Bagpuss
« Reply #55 on: April 23, 2018, 09:51:40 am »
Just received my DS1054Z (with 00.04.04 SP3 software), but have a slightly different situation to most.
Mine already came from the supplier with all options enabled (except 100MHz).
This raises a some questions:
1) What would happen if I ran :SYSTem:OPTion:UNINSTall?
     Would this remove all of the options, regardless of the fact they were pre-installed at purchase?
2) How do I put them back? The company I purchased from didn't provide any serial key.
3) Given that I've got the options already, is there a different code I should use to enable just the 100MHz feature?
     I was thinking that using DSER would be correct, but just wanted to be sure.
Any help would be much appreciated.
Thanks,
Andy.
« Last Edit: April 23, 2018, 10:03:54 am by Bagpuss »
Offline Fungus
« Reply #56 on: April 23, 2018, 10:30:09 am »
Yes.
Make your own keys with Riglol: http://gotroot.ca/rigol/riglol/
DSER will enable everything no matter what's already enabled.
Offline ebastler
« Reply #57 on: April 23, 2018, 10:30:52 am »
I assume the options would indeed be removed. Pre-installation at purchase uses the same mechanism as a post-purchase addition, to my knowledge, and hence removal of options should also work the same.
Either ask the seller to provide you with the key, or use RIGLOL to generate your own (presumably identical) key. Or just don't uninstall the options; no need to do that.
I would leave the pre-installed options in place, and use DSEA to just add the 100 MHz bandwidth.
EDIT: Fungus beat me to it. ;)
No real difference between our two posts. Either DSER or DSEA should work to enable 100 MHz on top of your pre-installed options.
« Last Edit: April 23, 2018, 10:42:10 am by ebastler »
Offline Bagpuss
« Reply #58 on: April 23, 2018, 12:08:49 pm »
Thanks. Just used DSER to enable 100Mhz.  :)
Offline Old Printer
« Reply #59 on: April 24, 2018, 03:51:28 pm »
Bagpus,  If I might ask, why did your scope come with all of the options pre-installed? I am assuming, always a dangerous thing, that the upgrade promotion was only based around furnishing the keys (usually from the dealer by email). Did your dealer install them for you? If so then you surely want the legit factory supplied keys for possible future use. I am wondering if Rigol has started enabling the options from the factory since everyone has them anyway, which I doubt. Thanks.
Offline BravoV
  • +++ ATH1
« Reply #60 on: April 24, 2018, 04:43:04 pm »
For any legit and genuine Rigol certificate, you will be sent this, and use the key (the highlighted in red) to generate the real key at their web site to get the final key to be entered in the scope.
Example below here ...
Offline Fungus
« Reply #61 on: April 24, 2018, 05:17:42 pm »
I wondered about that, too.
If you get the special deal you should receive an unopened box with the the 'scope inside and a separate certificate/coupon for your options. The dealer wouldn't pre-install the options for you because it's a lot of work for them, they'd have to unseal all the boxes, unpack the 'scopes and mess around with them entering keys.
So... what's the story? Did you receive your DS1054Z in a sealed box-within-box?
(Rigol puts two boxes on all their 'scopes)
Offline TheNewLab
« Reply #62 on: June 03, 2018, 07:09:25 pm »
My feeling is that Rigol is encouraging it, becausei nformation on how to do it is all over the Internet. It has been so for years. Rigol could have easily modified their software, at least to make it more difficult.
Why not encourage it? Just think of the overwhelming number of sales they are generating. They are making much more selling a large volume of units vs. trying to get people to pay the $100 or $200 for the extras.
 I would be really curious about how many units they sell an average year.
About dealers,(or sellers) doing the hack themselves. Except for the major distributors, it is a good way to get you to come back for future purchases. Once you get the rhythm, just get some person at minimum wage cracking away. If in China, labor is much less
Offline volbeast
« Reply #63 on: July 05, 2018, 09:53:54 pm »
I just upgraded my brand new DS1054Z today, the hack still works!
Offline rstofer
« Reply #64 on: July 05, 2018, 10:19:26 pm »
A couple of years ago I watched the inventory levels at Tequipment.  It appeared to me that they were selling about 1000 per week.  And that's just one supplier.
The new Siglents give them a run for the money but for awhile Rigol absolutely dominated the entry level scope market.  I really like my DS1054Z but I still want to buy the Siglent SDS1204X-E.  I'm kind of hanging back waiting on the firmware to get firm.  No hurry...
Offline TheNewLab
« Reply #65 on: July 06, 2018, 06:17:29 am »
Same here. the hacks on the Siglent so far are too technical to me. I would liek to learn to access code from a JTAG connector.
REgarding the Rigol. I just bought one. even with all the upgrades "official" I added the 100MHz upgrade with the suggusted code preference per these forum posts. worked fine. and did not lse the already installed upgrades.
Seller did not say anything about any included upgrades at all. just a base unit at a little over $200. hum.. maybe more. The box was still original manufacturer sealed. I think Rigol is just going ahead and including all upgrades except the 100MHz on these units now.
Offline ebastler
« Reply #66 on: July 06, 2018, 06:36:18 am »
As mentioned in the other thread: no guesswork required, Rigol does indeed include all options for free.  Presumably "for a limited time only", but the offer has been standing for months now. See here for example, under "free software bundle":
https://www.tequipment.net/Rigol/DS1054Z/Digital-Oscilloscopes/
The price you mention seems too good to be true, however, options or not. Where did you get the DS1054Z for "a little over $200"?
Offline BravoV
  • +++ ATH1
« Reply #67 on: July 06, 2018, 06:43:08 am »
Dunno why have the feeling that DS-1054Z's successor is about to surface ?  :-//
Offline Fungus
« Reply #68 on: July 06, 2018, 07:45:39 am »
And then all the new Siglent owners will cry out in pain!  :popcorn:
Offline OE2WHP
  • Country: at
« Reply #69 on: July 06, 2018, 09:28:04 am »
Most probably it "fell" from a truck....
Offline TheNewLab
« Reply #70 on: July 19, 2018, 02:29:50 am »
Ha! OE2WHP!! maybe you're right it was an Amazon delivery truck!! Tequipment was the source through Amazon. Amazon gave me a partial refund so and a quoted by net price - oops
It said nothing about any bundle, though. I had no idea until I went to another distributor who advertised a bundle but for around $500. I bought the thing..just so I could try out the hack. and had fun doing it, anxiety and all!
Fungus, not sure if Siglent owners will cry out in pain. their model has more standard features and a larger working screen. Now if they also drop their prices... or, drop the license and hardware add-on for the MSO..then we all will be crying out in pain.
Offline Fungus
« Reply #71 on: July 19, 2018, 02:40:19 am »
We can unlock them for free.
We're speaking about the secret, unreleased Rigol model, right?
They must be due for a new one by now and we know they've been developing their own chipset for a while.
Offline shorelineproductions
« Reply #72 on: March 09, 2019, 11:55:43 am »
I wasn't aware of the DSER option at the time I hacked my DS1054Z.  Currently I have the 500uV vertical option enabled.  Is there a method to disable this option?
Offline Fungus
« Reply #73 on: March 09, 2019, 12:46:08 pm »
a) telnet on port 5555
b) Type ":SYSTem:OPTion:UNINSTall"
c) :SYSTem:OPTion:INSTall XXXXXXXXXXXXXXXXXXXXXXXX
Where XXXXXXXXXXXXX is your DSER KEY
« Reply #74 on: March 09, 2019, 12:54:08 pm »
Thanks so much for the information, Fungus!
