Author Topic: HP E4437B Vector Signal Generator, replacement LCD?  (Read 1973 times)
Offline kazamTopic starter
« on: December 03, 2015, 12:04:02 am »
Just got an HP 4437B vsg, fully loaded with dual arb and extra signal memory. Great.   :-BROKE Also has AWGN which is great for receiver testing.
Everything works great but the LCD is a little dim. Common with these machines.
Does anyone know a source to get a new one? Is it even possible to get a replacement TFT? That would be sweet.
Thanks!
/K
Offline free_electron
    • SiliconValleyGarage
Re: HP E4437B Vector Signal Generator, replacement LCD?
« Reply #1 on: December 03, 2015, 12:32:22 am »
most likely the same lcd as in the infiniium scopes.
you can always swap the tube out.
« Reply #2 on: December 03, 2015, 09:25:28 am »
Right,
I'll have to open it up and check the CCFL. Did find some complete assemblies but they go for $250 so that's a bit of overkill.
Nice bit of kit none the less!
/K
Offline TheSteve
  • Living the Dream
VE7FM
« Reply #4 on: December 03, 2015, 10:37:07 am »
Check out this thread from a few days ago:
https://www.eevblog.com/forum/testgear/hp-agilent-e4433b-esg-d-series-signal-generator-250khz-4-0ghz/
Thanks, interesting. I did a search but somehow missed this. I will be ordering a new CCFL.
