Author Topic: DS1054z Square Output Problem  (Read 1854 times)
Offline m.m.mTopic starter
  • Country: ir
  • EE MSc Student and Hobbyist
« on: December 09, 2023, 10:20:21 am »
I lent my DS1054z scope to a friend and they apparently used the square wave output which is for probe compensation calibration, as an input for an opamp. I do not know what their circuit was, but after returning, the square wave output is limited to a 50mV voltage.
My guess is that they drew too much current and the output buffer of the square wave generator (if there's any) is blown up.  :-BROKE
I would appreciate your comments, or your experience if you had a similar accident.
25 y/o Electronics Lover
Offline modoran
Re: DS1054z Square Output Problem
« Reply #1 on: December 09, 2023, 10:30:14 am »
Just open the scope and see what's the problem there. And never lent to "friends" again.
« Last Edit: December 09, 2023, 10:34:16 am by modoran »
Offline TurboTom
« Reply #2 on: December 09, 2023, 10:52:50 am »
It seems there's one SOT32 device directly connected from the test signal output to ground, presumably a protection device (Z-Diode, transient suppressor) and then some RC stuff to the test signal generator "silicon" output. So the first item I would look at, especially if there's still "a little" of the signal present, is the protection device for a short. See here for a series of photos of the "later" PCB version.
I don't expect the test signal output can be damaged by shorting it to ground externally. But application of a reverse voltage would surely be able to cause some problem...  :o
The following users thanked this post: egonotto, m.m.m
  • Country: ir
« Reply #3 on: July 28, 2024, 10:33:42 pm »
I just had the time to open the scope (I've been quite busy  :-[). My multimeter reads a ~30 Ohm resistance from the test signal output to the ground. So I think the protection diode is short.
The diode has the marking "1UW". It appears that the part number is PESD5V0U2BT. Please correct me if I'm wrong.
I'll try to order a replacement and report the results.
Without the diode, the resistance is ~25k so I hope the rest is good.
« Last Edit: July 28, 2024, 11:17:19 pm by m.m.m »
Offline TomKatt
« Reply #4 on: July 28, 2024, 10:43:25 pm »
+1
Sounds like you are on the right track.
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline MAS3
« Reply #5 on: July 28, 2024, 11:04:02 pm »
I see some brownish stuff between the trough hole solderings, and the SOT32 part on your picture.
And all 3 trough hole solderings look a bit dodgy to me.
So i would resolder those (remove old solder and replace it) while you're at it, and clean up afterwards.
You might loose the lead free solder certificate, but reliability is nice to have.
Offline radiolistener
« Reply #6 on: July 29, 2024, 12:07:23 am »
probably some voltage was applied to calibration output. Also check if probes are alive, it is possible that it was used to measure voltage on RF transmitter output and probe was burned out, because 1:10 probe rated for 600 V DC can be damaged with >25 Vpk RF on the input. If probes are burned, it may show lower amplitude.
« Last Edit: July 29, 2024, 12:11:09 am by radiolistener »
  • Country: ir
« Reply #7 on: August 24, 2024, 06:08:54 pm »
Thanks everyone,
The diodes package just arrived and I replaced them.
It's working fine again!  :D
The following users thanked this post: marcus h, jasonRF
